Heater Box Removal
do you have to pull the fender off to get the heater box out?
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
#2 | |||
Union Electrician
Re: Heater Box Removal
I'm fairly certain you have to remove the inner fender to get to one of the bolts...
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Designated A-hole!
Check the FAQ Submissions page, there's an Index thread with a link to a write up on replacing the heater core. Should tell you what you need.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
collector of vintage rust
Non ac trucks dont require pulling inner fender.
![]() Join Date: Jul 2004
A set of 1/4 drive swivel sockets makes getting that lower right fastener off a little easier, yep, should not require removing the inner fender on non a/c trucks, if you have a real long and skinny arm, it is possible to reach up from the bottom of the fender to get that little bugger off also.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
mucho thanks guys
Next project: 1970 K10
Yup, 1/4" socket set with a long extension and a swivel. No problem.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
72 fleetside longbed 350
I have a non-ac truck and I removed all the top bolts/nuts easily the last one I broke lol. The only thing I took off to get it out of the engine compartment was the pass. side hood hinge so I could slide it out of the firewall lip. Hope this helps somewhat.
