06-28-2006, 05:28 PM | #1 |
C10 Club Tennessee
All you Serpentine guys!!!
I got all my stuff and I believe I'm almost ready to start. I've got the two big brackets at the sandblaster ready to be cleaned. My question is that I'm only seeing a select amount of holes for the brackets to be bolted onto. It looks like my head is missing a hole. I have all the bolts that are supposed to be in screwed in a little to show my problem.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
06-28-2006, 05:52 PM | #2 |
Designated A-hole!
Re: All you Serpentine guys!!!
I didn't have a hole there either, upon another members advice (Gman69 maybe?) I did without that bolt. You can't see it with the bracket installed and there seems to be no affect on its performance.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-28-2006, 06:01 PM | #3 |
C10 Club Tennessee
Hey Krue, which Alternator did you use? I know i need to go get a reverse rotation water pump from a early 90's chevy
06-28-2006, 06:05 PM | #4 |
Designated A-hole!
Bought an alternator for a 93 Silverado, (105 amp I think). The only thing I really had to modify was the bracket that runs from the back of the alternator to the back of the ps pump and front of exhaust manifold.
06-28-2006, 08:04 PM | #5 |
I'm not running that bolt\screw either. I guess if your anal you could drill and tap onr. I would make sure you use all or as many of the braces as you can though. Don't forget along with the water pump you need a reverse rotation fan for the pump (unless you are using electric fans) and a big block fan shroud. Also there is no heater return line in these water pumps so if you have earlier than a 71 radiator you will need to switch to one with the return in the radiator or rig somethine else up. Are your going to run A\C?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-28-2006, 08:37 PM | #6 |
Keep On Truckin'
I drilled and tapped that hole for my set up.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
06-28-2006, 08:58 PM | #7 |
C10 Club Tennessee
No, I will not be running A/C.
I have the braces and will definitely be using them. What do you mean a return on the radiator?
06-28-2006, 09:18 PM | #8 |
The return line that usually goes from the heater to the water pump instead goes to a fitting soldered to the right side of the radiator. I believe all trucks from 71 on did this.
06-28-2006, 09:23 PM | #9 |
C10 Club Tennessee
GREAT Another roadblock!!!!
06-28-2006, 09:37 PM | #10 |
Sorry, you should know by now nothing is as easy as it seems with these trucks especially when trying to upgrade to newer parts. I just switched radiators and water pump with my burb its a 71..
06-28-2006, 09:42 PM | #11 |
C10 Club Tennessee
Hell, I can't afford a new radiator
CRAP!!!!!!!!!!
06-28-2006, 09:57 PM | #12 |
even after 71 most of these trucks my self i have NEVER seen the heater hose on the rad and have owned plenty of 71+ trucks
Dan. 55 F100 panel truck project 64 350/th400/10bolt short fleet 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 2wd short fleet current build! 83 350/700r4 short fleet 88 k5 12" lift 3/4 ton swap mud toy 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops |
06-28-2006, 09:58 PM | #13 |
I have seen someone put a 'T' in the radiator hose with a nipple that would fit the heater hose.
06-28-2006, 10:01 PM | #14 |
HOLD ON!!! My reverse rotation long water pump has the coolant return in it. Purchased from O'Reilly's on my way up to Pigeon Forge in May, '05. I asked for a pump for a '93 or so C-1500 5.7. Hope this helps.
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
06-28-2006, 10:02 PM | #15 |
sounds like a plan to me if you can find a T
06-28-2006, 10:08 PM | #16 |
C10 Club Tennessee
George to save the day!!!!!!!!
Hey George I remember that day
06-28-2006, 10:15 PM | #17 |
The pasenger side A/C bracket, I only used the one bolt. 1, that is al I had drilled. 2. That is all the truck it came from used. Two of the holes on the driver's side head I used for the bracket, and one for a support brace.
My alternator is a 130 amp model. Watch out, the 105 and 90 amp models use a different plug (as I found out.) You should not need a new radiator. The water pump I got for mine (94 silverado 350) had a plug in it that I took out and put the heater hose nipple from the none serp water pump and put it on the serp one. Heater issue was solve. Gman69 did the same thing. Krue said his didn't ome with the boss to put on the nipple, so I guess it varies by brand. Make sur you get a new water pump with the plug, sio you can swap out the nipple. I, like Krue mentioned, modified the bracket from the rear of the alternator to the power steering pump. I trimmed off the area that goes to the exhaust manifold. I did notice with my new valver covers its real tight to remove a valve cover enless I remove the alternater and loosen that brace for some give. I only used the brace support that runs from the drivers head to the point behind the tensioner on the AC bracket. GMan69 and Putter aren't running any, and no issues yet. On another note, You will probably want to change your thermostat housing to one that ponts straight ahead instead of angled like the stock one. Your upper radiator hose will have some issues with the alternator. Dang George beat me to it on the water pump.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 06-28-2006 at 10:18 PM. |
06-28-2006, 10:23 PM | #18 |
C10 Club Tennessee
Thanks for the detailed description Bill. So you didn't use the hole at the bottom of the A/C bracket? I have a hole there so I can bolt it up at the bottom.
Thanks for the thermostat housing advice too. I'll have to find out what applications had a straight one on it. One more thing. What did your A/C delete pully run you?
06-28-2006, 10:27 PM | #19 |
I got a nice cast iron straight housing from NAPA.
06-28-2006, 10:33 PM | #20 |
Designated A-hole!
I used an old compressor that my buddy had lying around.
06-28-2006, 10:36 PM | #21 |
This is the one I bought for mine from Advanced Auto Parts.
Mr. Gasket Water Neck: Chrome; Late; 45 Degree Swivel; Chevy V8 Part Number: 9141G The AC Delete ran around $50 after shipping. I got it through Wes, but it may still be a dealer available item.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 06-28-2006 at 10:38 PM. |
06-28-2006, 10:41 PM | #22 |
C10 Club Tennessee
I believe I just found it on the Advance webpage for $35.
I'm trying to dechrome my engine so I'll see what they got up there when i go get the water pump tomorrow. By the way Bill, motor looks REALLY Good!!!
06-29-2006, 10:30 AM | #23 |
Active Member
Im a bit new to this serpentine issue, what year truck can I get this set up off of??
06-29-2006, 11:51 AM | #24 |
Professional Grade
Bascially any truck from about 88+ will have it. Maybe even 87s, I can't remember You can use a setup off a 4.3 as well. Just make sure that whatever you get has a normal 6 groove belt, rather than something crazy like 4 or 5, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-29-2006, 11:59 AM | #25 |
Active Member
I just bought a used gm fast burn 385 it was in a 96 Transam and the serpentine set up it is kind of weird, it has separate v groove belts for the powersteering pump and a low bracket on the passenger side i was thinking might be for the ac, i thought he might have changed it around a little when he put the new motor in and removed the ac. Anyway are any of these interchangeable and /or how much should i be looking to pay for a complete used setup??
