Old 06-29-2006, 12:55 AM   #1
chevymad
Door help
Was working on my truck project tonight. My passenger door fits awfully. The top of the vent window hits the window frame, the top/back of the door is gapped, space is even across the top and bottom of the door, but the rear lower corner is tight and the body lines are 1/4" lower then the ones on the cab. If I raise the door to meet the body lines, i lift the door into the gutter. If I move it back to clear the vent window, I hit the lower rear corner. If I tip the door to fit the front and back, the upper and lower edges are crooked.
Any ideas? I'm thinking I'll have to shave part of the door at the vent window for clearance, then cut the cab to even out the rear gap. Not sure what to do about the body lines.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 06-29-2006, 09:18 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Door help
no help, but ttt for ya!
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 06-29-2006, 09:26 PM   #3
chevymad
Re: Door help
Thanks, was just looking for this post.. got 3 pages in nowhere to be seen... you'd ttt'd it while I was looking!!
Old 06-29-2006, 09:32 PM   #4
72CSTC5
72CSTC5's Avatar
Re: Door help
Have you done any work to the cab as far as rockers or corner panels? If not take a look at where your hinge bolts the door side of the truck. These chevy trucks are known to crack around the hinges making it near impossilbe to line the door up correctly because it is not firm in that area making a sagging problem for ever. Also check for slack in your door hinge pins by lifting the bottom rear of the door while open to check for slack there. You will need no slack to even get started aligning the door. Also remove the door striker plate on the cab side while adjusting and then reinstall once your door is aligned. Good luck.
72CSTC5 is offline   Reply With Quote
Old 06-29-2006, 09:42 PM   #5
chevymad
Re: Door help
Yes theres work done. But the problem seems to be the door frame is parallelogrammed. In other words the verticals are parallell and the horizontals are parallel, but they arent square with each other. So I can either line up the front and back, or the top & bottom(that is if there was enough space) and then the other 2 seems will be angled. It looks like I'm going to have to do some cutting and reshaping of the door opening and the door itself. Pity the next guy who has to replace the door.
Old 06-29-2006, 11:04 PM   #6
Green Machine
Green Machine's Avatar
Re: Door help
Is your work area flat ? Are all the tires same size side to side and pumped up ? How are the cab mounts ?T hey will tweak the cab if it they are bad. I would be tempted to get a jack and a 2x4 and tweak the cab back into shape, can't "officially" recommend that though.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-29-2006, 11:15 PM   #7
chevymad
Re: Door help
Just went out and worked/looked at it again. It's definately been parallellogrammed. Need to borrow dad's portapower.. see if i can push it back about a 1/4" then the frame should come back into shape. Drivers side looks ok. There's been some damage on the pass windshield frame. It's hit something up there and pushed it back.
