Old 06-29-2006, 09:39 AM   #1
jimmyjohn
unlocking tailgate on 94 jimmy
Does anyone know how to unlatch the tailgate on a 94 jimmy if the key no longer works. There is no internal handle and the tailgate window button is inoperative. Once I get it open, I can replace the lock. Thanks for any help on this one
jimmyjohn is offline   Reply With Quote
Old 06-29-2006, 10:04 AM   #2
Joe67
67 is sold
Re: unlocking tailgate on 94 jimmy
I'm not sure. Are you referring to the S/T version of the Jimmy? I don't know if they still made the full size version then.
Maybe try some of the boards dedicated to those trucks like http://www.s-series.org/ or http://www.s10forum.com/ or http://s-seriesforum.com
you may have to sift through a lot of BS on those boards
You from Rochester Hills, MI?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 06-29-2006, 10:06 AM   #3
Welcome to the board. I moved your post to an area that might be better at getting an answer to your question.
Old 06-29-2006, 02:37 PM   #4
Tink
Tink's Avatar
If this is a S-series, one of the clips on the rod that runs from one side to the other may have slipped off or broken, so it won't release. You'll need to very carefully pry the latches loose to get tailgate to drop... you can't see them since it is shut, but if you look at another Blazer or maybe a pick-up, you could figure out how to get them to release. I can take pics and post them of my Blazer's tailgate and latches if need be...
Then you can remove the tailgate trim cover and check/fix the clip.
Also, this one isn't too bad... http://www.s-series.org/
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
