Is TCS on th-350 needed?
I got a th-350 tranny with a TCS, can I run it without the TCS? It is for a 69 (pre TCS) truck. Can I just plug the hole where the sensor is?
Thanx in advance Dano |
its all about the +6 inches
Re: Is TCS on th-350 needed?
Disconnect it, they run better without.
#3 | |
Junior Member
Clif '68 C/10 LWB, 327, TH400, 12 bolt |
The TCS switch on the trans. disables the distributor vacuum advance in first and second gears, and allows advance in third. Emissions crap.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Put all that stuff in a ziplock bag, mark it and save it. You may need it one day soon, I assume youv'e seen that our wonderful elected officials in Sac want to roll emissions tests back to 1966+.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() uh oh. I don't like the sounds of that. Has SEMA been involved yet? |
Thanx for the reply. I guess I'd better keep my air pump and components also.
Dano |
Yeah, SEMA has been involved. I was actually shot down a year or two ago but its like a bad dream it keeps returning.
