Old 06-29-2006, 06:24 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Question Blazer tank mounting question
I was wondering about using the flange on the Blazer tank to bolt directly to the bottom of the frame. I have the straps, but can't find the j-bolts. That, and I don't really like the looks of the straps. I have seen a couple of aluminum tanks done this way. Anyone ever seen a Blazer tank mounted this way??
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-30-2006, 12:35 AM   #2
wibilly
wibilly's Avatar
Re: Blazer tank mounting question
i don't have a blazer tank out to look at but i don't think it would be a good idea
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-30-2006, 01:07 AM   #3
WORNBRAKES
If I remember right, the flanges on the Blazer tank are about a 1/2 inch to short on each side to bolt it in. I may be wrong though.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-30-2006, 07:46 AM   #4
glock35ipsc
The flange almost completely covers the bottom of the frame. I am wondering why it would not be a good idea, as there are several versions of aluminum tanks that mount that way. Frame flex should not be an issue at all. I am wondering more about the strength of the flange.
Bob
Old 06-30-2006, 12:09 PM   #5
Deuce
Deuce's Avatar
I bolted the tank to the frame. They bolt aluminum tanks to the frame so I don't see why you couldn't bolt a steel one??
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 06-30-2006, 01:43 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
If you look at the aluminum tanks the metal is a heck of a lot thicker than that of the blazer tank. The aluminum tanks are designed and built to be bolted to the frame. Blazer tanks were designed to be held in place with straps. In my opinion the flange is much too thin too support a large amount of weight. A full tank of gas (20 gallons) will weigh about 120 pounds. I'd buy some J-hooks and install it properly. If they didn't need to be installed with the straps the aftermarket companies wouldn't have supplied the straps or j-hooks with them. My $.02.
I mounted mine a little differently than others, and unless you poke your head under the truck, you can't really even tell it's there and my truck is at stock height (I took the first pic while laying on my side.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-30-2006, 02:11 PM   #7
glock35ipsc
Thanks for the opinions guys! My only real objection to the straps is the looks of the straps. I am leaning towards fabricating a pair of "straps" from flat bar that bolt across the tank between frame rails. Then, I could also make a skid plate that would permanently attatch to the bottom of the straps
Bob
Old 06-30-2006, 03:54 PM   #8
Joe67
67 is sold
You could fabricate a nice smooth panel to cover the rear of the tank
Just make it removable in case you need to service the tank
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 06-30-2006, 04:12 PM   #9
glock35ipsc
That's kinda what I am thinking Joe. I've been sketching this out today.... I am thinking of making mounting "straps" that attach between the frame rails, side to side. Then , once the tank is in place, build a "box" all around the tank, using the straps as a means to attach the box. Then, it the tank ever needed removed, the tank, box and all will just drop straight down.
This was, I can cover the tank (paint the box body color??), and create a safety barrier all around it as well.....
Bob
Old 07-01-2006, 10:18 AM   #10
Joe67
67 is sold
Good idea. Initially I was thinking of a cover just over the rear of the tank.
But thinking about it, that would probably catch some air while you're driving...
