Old 06-29-2006, 07:20 PM   #1
skokie
skokie's Avatar
Best way to grind down welds?
Whats the best or most efficent way to grind down welds? Total noobie question to
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-29-2006, 07:32 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: Best way to grind down welds?
Grinding disc followed by a flap sand disc on an angle grinder. 4.5" angle grinders are cheap and work fine for body/small jobs.
Frizzle Fry is offline   Reply With Quote
Old 06-29-2006, 07:38 PM   #3
cdowns
cdowns's Avatar
i like using a die grinder with a 3" cutoff wheel i feel they do a faster job and generate less heat on sheetmetal// on frame work and things like motor mounts made out of 3/16 thru 3/8 metal i'll normally use an angle grinder
Old 06-29-2006, 07:47 PM   #4
jbon64
jbon64's Avatar
much agreed with the above , if you want the grind marks to disappear use a DA with a 120 disc after using the flap wheel
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 06-29-2006, 08:09 PM   #5
Rokcrln
Rokcrln's Avatar
I agree with all three post above and I have 3 4.5" grinders set up at all times!
1) 4.5" hard grinding disk
2) 4" .040 thick cut off wheel
3)4" flapers (grits per job)
Then for smaller spots I have 3 small right angle air grinders set up with~
1) 3" .040 cut off wheels
2) 2.5" 3m style spin on sanding disks
3) die grinding bits for real tight corners
and yes the DA trick for the real smooth look.
But the best trick short of TIG welding it (almost no raised weld) is to make sure you are using the right wire! For body panels I like to use .023 solid core wire with a 25/75% gas mix. Then adjust it for just enough weld for full penitration with out creating to large of a bead above the surface.
Oh ya and PRACTICE, PRACTICE, PRACTICE!!
Have fun learning and I highly recomend buying a few books on welding. Even if you know how to weld you can always learn a few more tricks. I have been welding for over 20yrs now (certified for almost 14 of that) and I just bought my first two welding books and so far (half way done with the first) they are great. I would have been so much farther ahead if I had done this 20yrs ago.
I know people will ask so here it is~
Both are by Richard Finch, (eastwoods)
1) welders handbook
2)Performance welding handbook
If you buy them read it front to back and do not skip over what you think you already know, you just may learn what you don't.
Good luck,
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-29-2006, 08:33 PM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
What is the purpose of the flap sand disc?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 06-29-2006, 09:07 PM   #7
A:getting rid of scars.
I use a cutting wheel.The rest is dress.
Old 06-29-2006, 09:32 PM   #8
Dano69c10
Dano69c10's Avatar
I have a stupid question, what is a DA?
Dano69c10 is offline   Reply With Quote
Old 06-29-2006, 09:43 PM   #9
BrianJordan
Iron Thunder
BrianJordan's Avatar
a good welder doesn't need a grinder.
i'm just kidding guys. i would be lost with out my grinder.
BrianJordan is offline   Reply With Quote
Old 06-29-2006, 10:29 PM   #10
dirtball
dirtball's Avatar
D ual A ction sander.
dirtball is offline   Reply With Quote
Old 06-29-2006, 10:47 PM   #11
wolfthing2000
For minimum grind and a flat weld: GAS WELD ( oxy-acetylene that is)
wolfthing2000 is offline   Reply With Quote
Old 06-30-2006, 12:24 AM   #12
mbgmike
Yeah i agree but don't grind too much. I use only Ingersoll- Rand because i got tired of burning up the cheap grinders. I can burn up 5 to 6 cheap ones a year. The I-R ones I have had for years now. Frizzle Fry knows how to do it. If you don't do it much a cheap tool will work fine.
Mike
mbgmike is offline   Reply With Quote
Old 06-30-2006, 12:28 AM   #13
mbgmike
If you are a production shop you do not use a DA to grind down welds.
Old 06-30-2006, 01:38 AM   #14
skokie
skokie's Avatar
Thanks for all the info guys. I appreciate it.
68 build thread
Old 06-30-2006, 06:12 PM   #15
badpeanut
badpeanut's Avatar
What is the best grit flap sand disc to get?
'70 GMC LWB trailer
Old 07-14-2006, 04:35 PM   #16
BigMike
BigMike's Avatar
Yep, then you'll have a nice flat welded piece that resembles a Pringles potato chip after it warps
Sorry, had to...
Mike
BigMike is offline   Reply With Quote
Old 07-14-2006, 10:49 PM   #17
wolfthing2000
IF you get it too hot youwill warp it............ How do you think the old school did it befor MIG??? OXY CETLIN!!!!
Old 07-14-2006, 11:50 PM   #18
67chevy2wd
67chevy2wd's Avatar
So what do you guys think of 0.30 wire? Is it better to weld short beeds or just to keep tacking until it is all welded up. It seems like just tacks would leave small pin holes.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 07-15-2006, 03:28 AM   #19
BigMike
BigMike's Avatar
True, but time changes and so does technology. For what we do to our trucks as hobbiests, there is no question that a MIG welder is far superior to Oxy-Acetylene. Kinda like cutting down the trees on your property using an axe instead of a chainsaw: lol:
Just razzin ya anyways, thought it was funny
Anyways, sorry for getting off topic.
I use a 60 grit and an 80 grit flap wheel. Never heard of one or thought it would do as good as it does, but they'll bust down welds pretty quick. I got mine at Home Depot, I think for like $6.00. They just thread right on to your grinder like the large grinding disks.
Mike
Old 07-15-2006, 03:35 AM   #20
BigMike
BigMike's Avatar
For the large stuff I use the .030, for sheet metal I use the smaller .025. You can turn the heat down a bit for the .025 so you get less burn throughs. You'll need to swap out for the smaller .025 tip too.
Mike
