Old 06-29-2006, 07:52 PM   #1
SactoJim
SactoJim's Avatar
Body Mounts / Body Line Alignment
Anybody ever have problems with body lines not lining up after installing new body mounts. My cab is probably 1/4" lower than the bed and looks like I will have to shim to get to line up. The bed can't go any lower. My concern is how will this affect the rest of the body panel alignment. Currently all body panels and doors are off the truck.
If anyone has had these probs, please let me know some tips and/or tricks.
SactoJim is offline   Reply With Quote
Old 06-29-2006, 08:25 PM   #2
matthufham
Re: Body Mounts / Body Line Alignment
poly mounts from gmc pauls? mine did that, i used a bunch of large/thick washers. it might require you to raise the core support the same amount, but somehow i got away with not doing it.
matthufham is offline   Reply With Quote
Old 06-29-2006, 08:34 PM   #3
MisterMan
MisterMan's Avatar
buddy cut up the bed and shoved the frame thru it. lmao, put it on baggs, truck fully smashed sets 1/4 inch about ground. rediclious. (1969')... just use some good ol' washers on the bottem side (imbetween frame and rubber.)
MisterMan is offline   Reply With Quote
