Vortec in the works
Renewing Black Plastic on Bumpers?
Are there any good ways to renew the black plastic on newer bumpers,88-98,your typical armour all and other detailing products are not cutting it anymore?
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
Re: Renewing Black Plastic on Bumpers?
I use this stuff i get at an auto body supply store. It works real good. I will see if I can find it in my crap. I forget the name. it lasts a long time like 4-6 months and then you notice a little fading
Vortec in the works
That would be great,is it a spray?
No it has a seperate foam applicator that you just run along going the same direction only. I looked this morning but haven't located it. I would go to the paint store but they are closed till tuesday. I may still find it. I've tried all kinds of other brands and this one works the best that I have found. I use it also to blacken sprayed on bedliners that turn a little lighter.
Vortec in the works
Thanks, I'm going to the paint store on tues anyway
i'll see what they have
OK quit looking
I found the bottle. its made by BONDO called Restore Black.Another good brand thats in a spray is Called "Black It Out' I use it alot. here is page from bondo http://www.bondo-online.com/catalog_...sp?itemNbr=847 Last edited by mbgmike; 07-02-2006 at 11:05 AM. |
Another product I've used is called "Black Again"- it works great, especially removing excess wax from black surfaces as well.
67 C10 LWB Stepside- 250cid 6, 3speed |
I have used a lot of products and I think that "Mothers" makes the best plastic polish out there amour all and other products will dull and crack plastic over time. The best way to keep your plastic in shape is a plastic polish
There's only one type of cool in the world and if you have to ask then your not cool |
| Bookmarks |
