Old 06-30-2006, 05:30 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Anybody rebuilt there PS Gear Box?
Has anyone done this or can help with it? I bought a gear box at the junkyard the other day and I got a 3/4 ton one, so it's pretty much worthless to me. I figured instead of going and getting another one that I might rebuild the one I have. It leaks at the top of the gear box where the steering shaft goes in.
I know that the parts stores sell two different kits for them. Don't know which one I'd need for to fix my particular problem.
One is the complete rebuild kit, another is the seal kit, and the last one is the Input seal Kit.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-30-2006, 05:34 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Anybody rebuilt there PS Gear Box?
A seal kit, possibly just that seal. I have rebuilt one or two, just pay attention to how it comes apart (mostly the number of turn on the nut from the steering shaft, too tight and it won't turn too good!)
70rs/ss is offline   Reply With Quote
Old 06-30-2006, 08:47 PM   #3
chevymad
I would change just the seal needed. I've done the whole box before.. Took me 2 kits because I ruined one of the teflon rings going together. Keeping track of all the balls is a bugger too. Next time I'll just buy a rebuilt unit if the whole thing needs doing.
Doing just the input or output seals though, isnt too bad to do.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 06-30-2006, 09:38 PM   #4
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
I've rebuilt mine...probably would not try it again. I would go reman. If you decide to do it, get the master kit and like chevymad said, be very careful with those teflon seals.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 06-30-2006, 11:58 PM   #5
5150
C10 Club Tennessee
5150's Avatar
So would it be this seal that needs to be replaced?
http://www.oreillyauto.com/EW3/ByKey...ring%20Gear%20
Bryan
www.gmtruckshow.com
Old 07-01-2006, 05:27 AM   #6
w314speed
The parts book lists the steering gears as the same for 10-30 series, so the 3/4 ton gear will work? After you remove the threaded plug and pitman shaft, take a piece of 3/8 fuel line or copper pipe and as you turn the flange the lower housing will move down and out, continue to push the hose into the center of the housing. Reverse the procedure to assemble. As long as you don't remove the hose or pipe the balls will stay in place.
Chevrolet and GMC published a Service Manual and an Overhaul Manual. Find and Buy the Overhaul Manual, its the best money you will spend, if you are doing the work yourself.
w314speed is offline   Reply With Quote
Old 07-01-2006, 08:08 AM   #7
5150
C10 Club Tennessee
5150's Avatar
The shaft is different on the one that I got from the junkyard. It came from a 79 Blazer. That's why I figured it was a 3/4 ton.
Bryan
www.gmtruckshow.com
Old 07-01-2006, 08:10 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Just buy ya a AGR like GQ
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-01-2006, 08:11 AM   #9
5150
C10 Club Tennessee
5150's Avatar
I'm not rolling in the $$$$ like GQ
Bryan
www.gmtruckshow.com
Old 07-01-2006, 08:24 AM   #10
Botietruck
Botietruck's Avatar
yellow69 PM sent
Old 07-01-2006, 09:12 AM   #11
5150
C10 Club Tennessee
5150's Avatar
I'm sorry I gave you guys the wrong link:
http://www.oreillyauto.com/EW3/ByKey...riptionId=2346
Bryan
www.gmtruckshow.com
Old 07-01-2006, 10:54 AM   #12
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I went the parts store remanufactured route. Cost just over $200. It was tight at first, but after six months it started getting sloppy again. I question the quality of the remanufactured boxes.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 07-01-2006, 03:26 PM   #13
5150
C10 Club Tennessee
5150's Avatar
I guess my question that I need to ask is which seal is it that I need to replace if it is leaking at the top of the gear box where the shaft connects?
Is it that Input Seal?
Bryan
www.gmtruckshow.com
Old 07-01-2006, 06:27 PM   #14
5150
C10 Club Tennessee
5150's Avatar
ttt
Bryan
www.gmtruckshow.com
Old 07-01-2006, 10:32 PM   #15
Botietruck
Botietruck's Avatar
If you want to replace the seals only, the ones where the rag joint attaches to the steering shaft, I believe you will have to buy the complete kit. When you take the big nut off be sure to count the number of turns. You might want to scribe a line on the nut and the housing just to make sure you put it back in the same place. I replaced one recently, but I cannot remember if I purchased the complete kit or a shaft seal kit. There are 2 lip-type seals in that nut. assy. and an o-ring or two. Good luck! Tell us how it turned out.
Bob
Old 07-02-2006, 05:18 AM   #16
w314speed
On the used gear, my wrecking yard told me the the 10-30 2wd truck gear was the same until 76.
Old 07-02-2006, 11:55 PM   #17
jimfulco
2WD and 4WD use different boxes.
jimfulco is offline   Reply With Quote
Old 07-03-2006, 02:18 AM   #18
longhorn70gmc
longhorn70gmc's Avatar
I was told the same thing. I still may rebuild mine. I have the kit, it's just getting the time.
Good thread,
Billy
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 07-04-2006, 12:36 AM   #19
incoma
incoma's Avatar
I think I bought mine from NAPA for $170. or was it $270. I thought it was worth the $ to not screw up my original box. I wish I could have gotten a different turn ratio particularly with my 8" rims.
incoma is offline   Reply With Quote
