07-01-2006, 12:45 AM | #1 |
Wtb: Rear original U-clamps(Good Luck)
Looking for original rear U-clamps for 72 Blazer. Need all 4 of them with bolts.
Im lowering back to original lift, but need the clamps. Thanks, Luis. |
07-07-2006, 03:08 AM | #2 |
Re: Wtb: Rear original U-clamps(Good Luck)
anyone.
07-07-2006, 08:22 AM | #3 |
Luis, contact any heavy truck spring shop. They either stock or can make up "U" bolts just like the originals for el-cheapo. I bought mine for less then you could ship them for, each with the washers and nuts. Most originals are metal fatigued, rusted or warn where they mount and are best thrown away.
07-07-2006, 08:54 AM | #4 |
Thanks for the info Huck. Ill problably look for a spring shop here in Vegas. Maybe its better to get them remake afterall. Never thought of that idea.
07-07-2006, 02:00 PM | #5 |
You looking for the cast metal brackets?
07-07-2006, 02:14 PM | #6 |
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
07-07-2006, 05:53 PM | #7 |
Rod, just looking for originals i dont know if they came with cast brackets.
71swb4x4, thanks for the info. Luis. |
07-07-2006, 11:44 PM | #8 |
Outlandish Trends - FL
Luis, u looking for u-clamps for a leaf setup? Or are you looking for original u-"bolts" for a trailing arm setup? If it's the latter, I have some originals. I'm assuming since you've got a 72 blazer that you probably have leafs. But then again you know what they say about people that assume.
-Bret 67 short-fleet sold! |
07-08-2006, 12:30 AM | #9 |
Good point, the ones I linked to were for coil springs.
07-09-2006, 08:25 AM | #10 |
I no longer need the u-bolts. Got them already. Thanks you all anyway, Luis.
