Old 07-01-2006, 05:15 PM   #1
1LoC10
Insert Title Here
1LoC10's Avatar
These tubular arms for stock shaft
what do you guys think of these? the drivers side is supposed to built to clear the stock shaft.. or would a multi link be just as good
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-01-2006, 05:15 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: These tubular arms for stock shaft
oh and its for when aired out and laying frame
BOBBY
_69 SWB_
Old 07-01-2006, 06:06 PM   #3
hotrods316
Man thats trick. Who built those control arms? I am planning on baggin a 67 step side and am trying to get a good knowledge base of everything. is you dont mind how much did they cost? Thanks and looks good!!
hotrods316 is offline   Reply With Quote
Old 07-01-2006, 06:35 PM   #4
1LoC10
Insert Title Here
1LoC10's Avatar
These guys.. and they dont have a price on them.. i havent looked that far into them yet
http://www.settintrendz.com/
BOBBY
_69 SWB_
Old 07-03-2006, 09:00 AM   #5
bodydropped
those are for a 73-87 trucks but would look killer on the 67-72s but they should clear because u can see were the notch is in the arms for the steerin arm
bodydropped is offline   Reply With Quote
Old 07-03-2006, 11:59 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
The arms are the same regardless of whether they are 67-72 or 73-87. They do look pretty sweet
bagged74 is offline   Reply With Quote
Old 07-08-2006, 04:07 PM   #7
smbrouss70
smbrouss70's Avatar
1LoC10, where did you find those pics? I've looked all over their site and found nothing on those arms. It looks like they z'd the frame or did a stock floor body drop, but either of those should move the steering box up in relation to the cab, which would not leave a straight shot from the bottom of the column to the steering box. Any more info on what they did to that truck?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-10-2006, 01:52 PM   #8
valleycustom
Those look good but I noticed one thing. Did they use DOM tubing for the arms?
Later
Jr
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 07-10-2006, 03:16 PM   #9
culookn
culookn's Avatar
whats the largest size wheel you can run with these? if they will allow a 22 to lay frame ill buy a set.
culookn is offline   Reply With Quote
Old 07-10-2006, 09:02 PM   #10
SCOTI
SCOTI's Avatar
Later
Jr
What if it's not DOM tubing?
Even if it wasn't, it should still be stronger vs. the stamped factory arms right? What do you guys think?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-10-2006, 09:31 PM   #11
1LoC10
Insert Title Here
1LoC10's Avatar
im not sure... this is the forum where I seen them... I don't know anyhting about these guys, but I was interested in them
http://www.streetsourcemag.com/forum...M=False&S=True
BOBBY
_69 SWB_
Old 07-10-2006, 09:40 PM   #12
valleycustom
The thing with factory stamped parts is it's high carbon steel which is stronger than mild steel. With DOM you don't have a seam that can split under stress.
Old 07-10-2006, 11:45 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
Later
Jr
Jr do you see an electricweld seam that I don't? You would think they're DOM or maybe even solid by the way the one side bent (no deformity). Looks like a good idea.
PBFAB.COM is offline   Reply With Quote
Old 07-11-2006, 12:44 AM   #14
SCOTI
SCOTI's Avatar
"I see said the blind man" . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-11-2006, 12:49 AM   #15
PBFAB.COM
PBFAB.COM's Avatar
Now I see it... I think the new black background made it jump out at me in the last pic!
