07-01-2006, 07:34 PM | #1 |
In Progress
removing rear leafs on 73-87 2wd
im trying to install a rear axle flip and trying to remove the leafs. im having trouble removing the bolts for the springs... seems like there stuck to the bushings. whats the best way to do this?
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
07-02-2006, 01:16 AM | #2 |
Re: removing rear leafs on 73-87 2wd
cut the head off or the nut and buy new bolts
07-02-2006, 03:02 AM | #3 |
cutting the head off the bolt will only let you beat it in both directions. It will still be just as stuck! Get ready to either take time getting it out or buying new rubber bushings! If you want to keep the bushings, wd-40 the bolts, let them set over night, take a bfh and beat the bushing end of the spring a while, wd-40 again, continue till they come off! If you want them off now, take a cutting torch burn the bushing out, heat the center sleeve, and then beat the bolt. you may have to heat then beat a few times but it will work. The only other option is cut the bolt on both sides of the spring and replace the bolt and beat the middle out after the spring is loose.
07-02-2006, 11:17 AM | #4 |
I tried the WD40 soaking method w/o success. I wound up having to knock the front hanger rivets off the frame & then used a shop press to press the bolt out (yes.... it was that stuck!).
I got new bolts from a specialty nut/bolt place for the spring ends which I coated liberally w/anti-sieze & used Grade 8 hardware to bolt the front hangers back on.
07-02-2006, 11:25 AM | #5 | |
Iron Thunder
07-03-2006, 01:13 AM | #6 |
In Progress
ya so what ive done is took the angle grinder and the through the bolts between the spring and the hanger. So now i just need to pess the old bushings out and get new bolts. thanks for the tips tho
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd Last edited by 1974gmc; 07-03-2006 at 01:13 AM. |
