Old 07-01-2006, 07:36 PM   #1
robsm88
robsm88's Avatar
trouble lowering 71' leaf rear, want bags
OK, so here is the question. What is the best way to bag it in the rear, since I don't have trailing arms. All the trailing arm brackets are still there though.
I am in the process of setting up the chassis for my GenIII swap. Now I hit a few new problems. I did the rear flip but I am not happy with the results. Witht the amount of work to set up everything, I think I will just bag it instead.
The flip gave me more drop than I planned, so now front is too high.
The shocks sit too horizontal to work properly so I need to relocate mounts.
The axle is now too far forward in the wheelwell.
robsm88 is offline   Reply With Quote
Old 07-03-2006, 12:25 AM   #2
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
Re: trouble lowering 71' leaf rear, want bags
Any pics of how it turned out?
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 07-03-2006, 12:52 AM   #3
Musclerodz
Air Ride just came out with a Air Bar rear setup recently. I belive it was being discussed in the suspension section.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 07-03-2006, 01:01 AM   #4
Shane
Shane's Avatar
Dont' waste your money with Air Ride. Over-priced parts to go along with their inflated egos and cheesy decals.
You can bag your truck for less than half of what ART charges for one of their "kits" ... do a search for "air bags" and you should have a couple of days worth of reading.
Shane is offline   Reply With Quote
Old 07-03-2006, 05:57 PM   #5
Primered_69
Primered_69's Avatar
Try this thread for an ideal about leaf and bags
http://67-72chevytrucks.com/vboard/s...d.php?t=158440
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 07-03-2006, 10:12 PM   #6
robsm88
robsm88's Avatar
Here are some pics.
After researching, I am definitely gonna do 4-link. What are the benefits of parallel vs triangulated. I understand what they are, but which works better for bags? I am not building this truck to lay frame. My biggest concerns are performance.
Old 07-03-2006, 10:51 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by robsm88
After researching, I am definitely gonna do 4-link. What are the benefits of parallel vs triangulated. ....
The intended advantage of a triangulated 4 link over a parallel is not having to use a panhard rod to locate the axle. If you have enough room to triangulate the bars it can be effective. If you go with a 4 link, I think you would be better off using a parallel set up.
Another option if your not trying to go really low is a bag over leaf set up like I used on my 77 Cheyenne...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-04-2006, 08:42 AM   #8
72MARIO
72MARIO's Avatar
That is a coil frame. Just so you know.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-04-2006, 10:37 AM   #9
robsm88
robsm88's Avatar
Thanks, I did know that, The PO used a camaro rear I believe. The leafs are only 2.25 wide which has been a big pain so far. All the trailing arm mounts are still intact, but I would rather not go back that route.
Old 07-04-2006, 03:31 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Consider this...
Articles-
"Refining Sierra"
Old 07-04-2006, 04:12 PM   #11
chevymad
These trucks used the narrow leaf's.. the 73 ups arent a direct bolt in.. 1/4" wider. I used a 74 rear in my leaf sprung truck with the flipkit it works fine on the early leaf's.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 07-04-2006, 04:23 PM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Truck I saw on the internet had leafs w/ bags, it will work
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
