rear cab trim
HELP !!! How do you get the trim off that runs across the back of the cab under the window? I sure dont want to mess it up. Thanks.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
Saving 1 truck at a time!
Re: rear cab trim
Use a putty knife and slide it under the trim. It just clips over a small plastic piece. There are 12 clips, one on each corner one near each drip rail and the rest across the back. The trim is "u" shaped and just pops over the plastic piece which is about 1/2" long.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 07-01-2006 at 11:42 PM. |
Re: rear cab trim
if it just pops on and off them clips why do them clips need to be put on them studs ?and why couldn't a guy put them clips with pop rivets or sheet metal screws? i know you can buy screw in studs for a cab that didn't come with cab devider trim but they are so short that if your cab was dented [as so many are in this area]and has any filler at all are to short
common sense isn't so common anymore |
Re: rear cab trim
Them studs is holdin`the clips to the body,so they`ll stay.Like stl said,the trim is just "popped" over them clips.It takes care to install/remove.
Re: rear cab trim
thanks everyone. i will try it today.
Like a Rock!
Re: rear cab trim
If your plastic clips are old don't be suprised if you mess a few up on the edges from removing/installing.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Re: rear cab trim
thanks, i have a new set of clips.
Re: rear cab trim
i have new clips and i bought the screws that are made to go with them to use on cabs that wern't oraginaly equiped but they are very short and my cab was dented and filled so i'm worried they wont all catch metal
