Old 07-02-2006, 06:32 AM   #1
moneyeater
moneyeater's Avatar
Too much leafs
Hello folks,i know that this was discussed here before but i couldn´d find it!
How many leafs can i take out of my spring pack to get a smoother ride?
Now there are 6 plus the overloadleaf and the ride was very stiff and bouncy from what i remember.When i rode it the last time it had 31x12.5 tires and old "outoiler" shocks,now the axle is flipped and it has 295/50s and belltech nitro drop shocks on!
Yesterday we pulled the bed of to get the rest of the electrical lines on and fabricate an exhaustsystem,remove the driversside fueltank to get room for a LPG tank and that is the best time to get the springpack rearranged too!
moneyeater is offline   Reply With Quote
Old 07-02-2006, 01:53 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Too much leafs
This thread (http://67-72chevytrucks.com/vboard/s...d.php?t=196993) discussed a 8-leaf spring pack. In your case, I'd leave the overload and remove 1 (maybe 2) of the bottom-most leafs.
BTW, it's looks good.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 07-03-2006, 01:10 AM   #3
1974gmc
In Progress
1974gmc's Avatar
Re: Too much leafs
my truck has 3 leafs and then the overload so 4 in total
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 07-03-2006, 03:06 AM   #4
1972C10
1972C10's Avatar
Re: Too much leafs
My Truck Rides Like A Tank With These CUCV Truck Springs 9 Leafs
1972C10 is offline   Reply With Quote
Old 07-03-2006, 11:41 AM   #5
moneyeater
moneyeater's Avatar
Re: Too much leafs
So how is your ride? Smooth,bouncy,stiff???
Old 07-03-2006, 11:46 AM   #6
moneyeater
moneyeater's Avatar
Re: Too much leafs
That is a very thick leafpack! Should take a lot of load doesnŽt it?
I think iŽll only haul my butt and the fuel in the tanks around!
Old 07-03-2006, 12:32 PM   #7
1974gmc
In Progress
1974gmc's Avatar
Re: Too much leafs
i dont find its too bad, its a truck so its to be expected. it smoother on some roads than my mustang.
Old 07-03-2006, 12:48 PM   #8
1972C10
1972C10's Avatar
Re: Too much leafs
Ive Hauled Alot With Them I have been Thinking Of Taking A Few Out Though.
Old 07-05-2006, 03:04 AM   #9
BigDan3131
BigDan3131's Avatar
Re: Too much leafs
If this will be pleasure only ride you dont need an overload spring. Some of your issue might be the bump stops hitting the frame all the time. If you did a flip kit you should have notched the frame.
BigDan3131 is offline   Reply With Quote
Old 07-05-2006, 10:10 AM   #10
bodydropped
Re: Too much leafs
i have a flipkit and i got 10 leafs on each side and its pretty dang low but was made to tow
bodydropped is offline   Reply With Quote
Old 07-05-2006, 01:31 PM   #11
moneyeater
moneyeater's Avatar
Re: Too much leafs
@bigdan: here in germany i could get in trouble with the technical inspectors when i cut the frame or change the original specs!
There´s about 2,5 " of room between the bumpstops and the axletubes.I think that shouldn´t bottom out to bad!?
Old 07-05-2006, 01:42 PM   #12
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: Too much leafs
ThereŽs about 2,5 " of room between the bumpstops and the axletubes.I think that shouldnŽt bottom out to bad!?
Man ur good to go with out a notch, just dont do 60 over speed bumps. my buddys 85 has about 3/4 of an inch it needs notchd. it bottums out alot, but his springs are crap i think cuz i weigh 250 and it sits on the axle when i get in the back.
AesC10s is offline   Reply With Quote
Old 07-06-2006, 04:24 PM   #13
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Too much leafs
You can pull 2 out of that pack and be ok.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
