Old 07-02-2006, 12:07 PM   #1
dharhigh1
Another Newbie with a tranny question.
Hello All! I've been reading this forum constantly and you all have been very helpful. Two weeks ago I picked up my 72 C10 LB 350/350, which I have wanted one of these forever. It has just been painted and the engine rebuilt, it has plenty of new parts all over on it and I got it for $2,775.
It does have some small things I am dealing with mainly electrical like the gages etc. Also the rear seal is leaking in the transmission (Turbo 350) and I have a carrier bearing midway, any tips that you can offer on changing this rear seal out. I have already bought it so I just need to do the dirty work.
Thanks in advance,
Dan
dharhigh1 is offline   Reply With Quote
Old 07-02-2006, 12:57 PM   #2
Sweet72
Sweet72's Avatar
Re: Another Newbie with a tranny question.
If your t350 rear seal is leaking it's very likely that the output shaft bushing is the cause. Relatively easy to change, remove rear u-joint u-bolts and drop driveshaft, pull bolts that mount center carrier brng., shaft will just slide out of tranny. Have a drip pan under the tail shaft to catch fluid. remove four bolts that hold the tailshaft housing on. Remove tailshaft hsg. and pull seal and take note of location of bushing, carfully drive out bushing. With a bushing driver or appropriately sized socket, drive new bushing in the same position and install new seal with aviation form a gasket around it's perimeter. Reinstall everything and your done. Might be a good time to replace carrier bearing and check u-joints.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-02-2006, 02:09 PM   #3
dharhigh1
Thanks for the help, the carrier looks like it's new.
Truthfully the rear seal in the tranny does too, that may be why what your saying makes sense and that it is the shaft bushing.
Thanks again,
Old 07-02-2006, 02:38 PM   #4
TugOwar
Welcome from South TX
TugOwar is offline   Reply With Quote
Old 07-02-2006, 08:32 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-13-2006, 10:18 PM   #6
68haywagon
I'm watching you!
to the board!!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
