Dash replacement... anyone ever done it ?
As most of you know my hauler was vandalized many years ago and ALL of the glass and lenses were broken out of it. Apparently they stood and stomped on the windshield and did some pretty significant damage to the top of the dash. The top area where the vents and radio speaker grille is wavy and bent from their destructive efforts.
Re: Dash replacement... anyone ever done it ?
You should be able to replace the whole dash fairly easily. There are spot welds along the windshield seam, and them a couple bolts on the sides and then it should come out. Bolt the new one on and weld up the spot welds and you should be good to go.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Many guys on this board have replaced the entire dash, mainly because a previous owner hacked up the radio hole. Never done it myself but as described above it is pretty simple.
WTB this ad
One of the dash pad covers that go all the way down to the windshield might be a good option. I know this is only masking the problem but you know what they say, "out of sight, out of mind".
Here ya go...I replaced my dash a while back, it is not hard at all.
Mike PO used a jack hammer to make way for a home entertainment center ![]() ![]() You can see the holes where the spot welds were ![]() New one welded back in ![]() Front side before I ground down the welds ![]() Last edited by BigMike; 07-02-2006 at 03:53 PM. |
