Old 07-02-2006, 08:00 PM   #1
robsm88
robsm88's Avatar
need help bagging 71'
OK, so here is the question. What is the best way to bag it in the rear, since I have leafs and don't have trailing arms. All the trailing arm brackets are still there though.
I am in the process of setting up the chassis for my GenIII swap. Now I hit a few new problems. I did the rear flip but I am not happy with the results. Witht the amount of work to set up everything, I think I will just bag it instead.
The flip gave me more drop than I planned, so now front is too high.
The shocks sit too horizontal to work properly so I need to relocate mounts.
The axle is now too far forward in the wheelwell.
robsm88 is offline   Reply With Quote
Old 07-02-2006, 11:04 PM   #2
SCOTI
SCOTI's Avatar
Re: need help bagging 71'
The best way to bag it would be to go 4-link for the rear. If installed properly, it will allow you to adjust your ride height to be level vs. the front; it would fix the shock angles so they work; it would allow you to set the wheelbase to your liking.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-03-2006, 01:50 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
I agree with Scoti. Four link in the rear, parallel or triangulated, will be the best method.
PBFAB.COM is offline   Reply With Quote
Old 07-03-2006, 02:26 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Four-link= Best
Trailing arms= Easiest/Cheapest
Just find some trailing arms in the JY or from a board member and bolt the bags in place of the stock coil springs. Stupid easy.
Relocators will fix your shock problems.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-03-2006, 10:34 PM   #5
robsm88
robsm88's Avatar
After researching, I am definitely gonna do 4-link. What are the benefits of parallel vs triangulated. I understand what they are, but which works better for bags? I am not building this truck to lay frame. My biggest concerns are performance.
Old 07-03-2006, 11:35 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
Parallel Four-Link is my preference on these trucks. Advantages: Pinion angle stays consistent through-out travel, if panhard rod is mounted correctly low roll center is achieved. Disadvantage: Axle will shift side to side through-out travel (longer the panhard rod, less side to side movement. The amount of shift through travel will be negligible, but it does move).
Old 07-04-2006, 11:37 AM   #7
robsm88
robsm88's Avatar
Thanks for all the input guys. I think I will go the parralel 4 link route. Suicidedoors needs my dimensions to order. I wish there was a list somewhere of what I need from someone that has done this allready. Anyone have a picture of a nice setup like this or links to this. I have searched all the 4-link threads on here, but it still leaves a lot of guees work. I will be welding this in.
Thanks again guys.
Old 07-04-2006, 12:02 PM   #8
SCOTI
SCOTI's Avatar
Suicide Doors should be able to give you a complete rundown of everything that you would need to completely install one of their 4-link kits.
If they can't help you, try ART or another manufacturer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2006, 12:43 PM   #9
robsm88
robsm88's Avatar
I tried suicide doors and didn't get much help. Love there prices and selection though.
Old 07-04-2006, 01:07 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
You may want to look at Air Ride Tech. They are a little more expensive but you will get the help you need and they will tell you what you need.
When you figure in the shippng and total cost they are really not that much more. It should be 10 -12% of the parts cost unless its very heavy or over sized.
dwcsr is offline   Reply With Quote
Old 07-04-2006, 02:40 PM   #11
robsm88
robsm88's Avatar
I like this setup, but can someone help me understand where the end with the brackets usually gets mounted (not the axle tube end). I just can't figure out what those brackets mount to.
Photo taken from *****************
Old 07-04-2006, 04:49 PM   #12
SCOTI
SCOTI's Avatar
They mount to the side of the frame. You weld them in place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2006, 07:30 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
You want the links parallel to the ground, or slightly angled down in front (slightly means 1 degree) at ride height. Mount the panhard bar as low as you can behind the rear axle, and have it parallel to the ground at ride height.
As far as who to buy from, I like Air Ride Tech. and am a dealer for them (I offer 10% discount to all board members).
Old 07-04-2006, 10:10 PM   #14
robsm88
robsm88's Avatar
Thanks, how do I order from you?
Old 07-05-2006, 01:26 AM   #15
kyle4381
Just go to Nathan's website his contact info is on therehttp://www.porterbuiltstreetrods.com
kyle4381 is offline   Reply With Quote
Old 07-05-2006, 10:40 AM   #16
robsm88
robsm88's Avatar
Thanks for the info, He has allready contacted me.
Old 07-05-2006, 09:16 PM   #17
robsm88
robsm88's Avatar
For anyone else that needed info on this too, here is a great article from classic truck magazine that Nathan advised I check out. Thanks again Nathan.
http://www.classictrucksweb.com/tech...air/index.html
