Old 07-02-2006, 09:48 PM   #1
71STPSDE
71STPSDE's Avatar
Help
I was removing all the hardware off the interior of my doors. I had a problem screwing out one of the screws on the arm rest. I had to cut off the head of the screw to remove the panel. Some how the nut that is attached to the door got unattached. Where can I get a new one. And what is it called?
71 Chevy Stepside
377/350
71STPSDE is offline   Reply With Quote
Old 07-03-2006, 01:18 PM   #2
71STPSDE
71STPSDE's Avatar
Re: Help
Somebody has to have an idea what this piece is called. They are attached all over the inside of the door. It attaches the armrest and the door panel to the door. Like I said in my previous message; mine some how got unattached from the door. I would like to use the old one, but the screw is stuck in the nut. I need to get a new one. What is it called?
71 Chevy Stepside
377/350
Old 07-03-2006, 01:25 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Help
I thought those were spot welded in from the backside ?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-03-2006, 01:48 PM   #4
71STPSDE
71STPSDE's Avatar
Re: Help
Mine are just inserted in the hole. The one that is still attached is not spot welded. It's got a flange that clips on to the door and the nut is on the inside of the door.
71 Chevy Stepside
377/350
Old 07-03-2006, 05:14 PM   #5
matthufham
Re: Help
for the armrest i think they use J nuts. they slip on and you can screw threw em.
matthufham is offline   Reply With Quote
Old 07-03-2006, 06:59 PM   #6
john
member #16
john's Avatar
Re: Help
Wes at http://www.classicheartbeat.com/ has the armrest capture nuts.
john is offline   Reply With Quote
Old 07-03-2006, 07:09 PM   #7
MisterMan
MisterMan's Avatar
Re: Help
thoes are spot welded from the back side usally, if ya broke one 4rm the door, replace it. and yes, thoes are usally the door arm rest's. a lil tip, when re assembling it all, add some "no sieze" to the bolts.
MisterMan is offline   Reply With Quote
Old 07-03-2006, 07:31 PM   #8
7T1BURB
Re: Help
Often called "Caged (or Captured) Nuts", another solution is to use the plastic license plate mounting inserts (that go into the bumper); insert in door and screw the arm rest retaining screw into them. Works OK! BTW: most caged nuts are welded into position and after years of rain/moisture entering the door inside, the arm rest screws are prone to rust onto the nut and when trying to remove the armrest screws (now firmly rusted into postion) it has a tendency to "break the weld". Have used the license plate nylon securing nuts with great success on many vehicles to replace caged nuts.
For your consideration....
7T1BURB is offline   Reply With Quote
Old 07-03-2006, 08:51 PM   #9
71STPSDE
71STPSDE's Avatar
Re: Help
That's exactely them. I'll order some of them. I also noticed that the drivers door had the license plate nylon nuts. I'll just order new ones. Thanks for all your help.
71 Chevy Stepside
377/350
Old 07-03-2006, 10:39 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Help
You may be able to get them from your local W.W.Grainger or other industrial supply house or you can usually find an automotive fastener supply.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-05-2006, 12:55 AM   #11
Bob Moore
Re: Help
At one time they were available at Lowes.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
