Old 07-03-2006, 11:45 AM   #1
makovai
makovai's Avatar
does anybody have a left turn signal that works?
I have now replaced everything in the steering wheel and still cant get my left hand turn signal to turn off atomatically. What a poor design. My 73 blazer had the same problem. Any suggestions?
If i let my seatbelt hanging out the door making sparks i could be the perfect nerd.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 07-03-2006, 12:33 PM   #2
IGOR
IGOR's Avatar
Re: does anybody have a left turn signal that works?
What do you mean "if?"
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 07-03-2006, 12:48 PM   #3
makovai
makovai's Avatar
I mean if it was longer i could make the sparks. Too much lift, it wont reach the ground.
Do your turn signals turn off?
www.fast77.com
1996 Z71 w/ 35's
Old 07-03-2006, 01:20 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
No issues here, mine all works like new
Owner/Op: "TN Classic Transport Carriers"
Daily Driver: "HerNameIsRio" 68 GMC SWB
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Toy Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-03-2006, 02:28 PM   #5
vtblazer
vtblazer's Avatar
Absolutely, on every single one of my trucks.
Is the steering wheel straight? (sound strange but it does effect thing's)
Are you using the correct turn style?
Two different kinds, one for tilt and one for standard columns.
Check the springs on the signal plate, if their broke they won't cancel.
vtblazer is offline   Reply With Quote
Old 07-03-2006, 05:19 PM   #6
makovai
makovai's Avatar
Well, as mentioned above, ive replaced everything in there including the springs 2 or 3 times. I dont remember if the plastic retainer was for tilt or not. I better investigate that.
It's a simple stupid problem but it is quite annoying wondering how far ive beend driving with my turn signal blinking.
www.fast77.com
1996 Z71 w/ 35's
Old 07-03-2006, 05:27 PM   #7
SOON2BLAZE
SOON2BLAZE's Avatar
Mine does not cancel either. I changed out the cancelling cam, but it didn't do any good. I should of changed out the whole unit.
SOON2BLAZE is offline   Reply With Quote
Old 07-03-2006, 05:33 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Mine dont shut off either but who cares........ Gotta get more important things done like floors so I can take the top off..... Working on that today should be topless this pm.....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
