Old 07-03-2006, 08:50 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Power Brake Conversion Help
Guys & Gals, I need some help. I swapped everything from a 3/4 ton truck to my C-10. I had a few issues, like the master cylinder is switched front to back, etc. But I got it all together except one thing. The brake pedal to booster push rod. I did get the one from the doner truck, but it is about 1/2" too short. If I hook it up to the pedal, the pedal is depressed like half way and the brake lights come on. Is the piece that bolts to the pedal also longer than the C-10? I didn't take that piece, just the one that hooks to the linkage behind the booster.
If that isn't it, I'm at a total loss for ideas. Help! I can't drive my truck!
HG
hgs_notes is offline   Reply With Quote
Old 07-03-2006, 09:25 PM   #2
JimKshortstep4x4
Talking Re: Power Brake Conversion Help
The adjustable rod between the pedal and the booster on our K-20 setup is 9"
as measured from center of hole to center of hole. All of the power brake pedals that we have in our trucks are lower than the non-powered brake pedals. (I can measure one tomorrow if no one else posts a measurement). The brake light switch is adjustable.
Jim
Old 07-04-2006, 12:18 AM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
Jim, are you saying that the with power brakes, the peddle at rest does not rest against the stop? I like the idea of having the pedal lower, it just seems so wrong. But thanks for the info.
HG
Old 07-04-2006, 12:27 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is correct. It sits a couple inches lower.
Old 07-04-2006, 01:33 PM   #5
ChevyDude
That's nice to know...I wondered why my new PB set-up didn't touch the stop pad ...Guess now I know!!!
ChevyDude is offline   Reply With Quote
