Old 07-04-2006, 10:37 AM   #1
jamon8
jamon8's Avatar
putting a nv3500 in a 67-72 c-10
first of all you have to make provisions for the clutch pedal.
I cut the firewall in the 89 donor truck and welded it in place on my 69 c-10
jamon8 is offline   Reply With Quote
Old 07-04-2006, 10:39 AM   #2
jamon8
jamon8's Avatar
Re: putting a nv3500 in a 67-72 c-10
then you have to cut the bottom of the cowl inside the cab so the clutch assembly will fit
Old 07-04-2006, 10:41 AM   #3
jamon8
jamon8's Avatar
then cut a hole in the floorboard. You can get the general idea from the placement in this picture
Old 07-04-2006, 10:45 AM   #4
jamon8
jamon8's Avatar
nest move the crossmember back about 3 inches
the bolt holes were predrilled in my frame. and cut a slot between the two holes in the bottom of the 350 crossmember so you can put the nv3500 trans mount through and have a bit of room for adjustments
Old 07-04-2006, 10:54 AM   #5
jamon8
jamon8's Avatar
a shortshaft 350 driveshaft works on a shortbed if you change the front yoke.
the Nv3500 is about the same size as a 350.
I put it behind a pre 87 small block so I had to get the older style flywheel to make it work
I suggest changing the clutch fork and the slave cylinder because these were week spots in the gm design. also make sure to use sycromesh in the tranny
Ask what you will, I will try to get back to you guys in a timely fashion!
Old 07-04-2006, 11:05 AM   #6
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Hey jamon8 glad to see the write up. Congrats on a job well done.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 07-04-2006, 05:09 PM   #7
Brad
Out of the carpool lane.
Brad's Avatar
Thanks for the write-up. I assume you did this with a V8?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 07-04-2006, 05:25 PM   #8
chevytrucks79
Thanks for the report and the pictures. My crossmember is all the way to the front like it last had a smaller 3 speed in it. It looks to me I am going to have to take it back further, if it will even work. I will probally have to make or find one that will work.
chevytrucks79 is offline   Reply With Quote
Old 07-04-2006, 11:49 PM   #9
chevybill
chevybill's Avatar
I am using this tranny also. Do you have any pics of the pedal setup inside the truck? Did this tranny come out of a full size truck?(shifter location looks perfect) I have this tranny with a vortec 350 on tubular motor mounts in the v 8 position and I was able to use my stock driveshaft. My particular tranny came from a 4.3 s-10 so the shifter looks to sit further back than yours.
Thanks so much for posting this.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 07-05-2006, 09:48 PM   #10
chevybill
chevybill's Avatar
Can you provide pics of the pedals mounted inside the cab?
Old 07-06-2006, 08:10 AM   #11
jamon8
jamon8's Avatar
you guys will have to wait a while for that because I am in the process of painting the cab!
