6 Bolt wheels
Will these newer style Silverado 6 bolt wheels fit on my 69 GMC 1/2 ton?
Tires are BF GOODRICH RADIAL LONGTRACK T/A 245/75R/16
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Next project: 1970 K10
Re: 6 Bolt wheels
If I remember correctly, the center bore is too small.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Re: 6 Bolt wheels
If it helps any there are off of a 2001 Silverado.
97' Tahoe 2dr/2wd
Re: 6 Bolt wheels
i have heard the same thing, the center bore is too small, and i believe the ofset is not correct
Re: 6 Bolt wheels
Lots of off set in those newer wheels, something like 5".
I've heard of guys having the centers machined out to fit. |
Re: 6 Bolt wheels
Not looking for a lot of work, just a deal on a set of wheels and tires.
Re: 6 Bolt wheels
I tried the use the ones off of my 2003 Silverado on my 68, and thats when I found the center bore to be too small. The bolt pattern is metric (I think), but will work. Might be worth a call to a couple of machine shops to see what it would cost to chuck them up in a lathe and open them up a bit. Would be really easy if you could find a lathe with a big enough swing.
Outlandish Trends - FL
Re: 6 Bolt wheels
All replies about the center bore being too small are correct. I ran into the same problem with the wheels I'm currently running. I chose to pull the axles and have the flanges machined down to correct it. Up front I was fine since I have a late-model disc conversion. I am running 1-1/2" spacers out back to correct the backspacing issue. Up front, no spacers as the drop spindles and disc conversion already gave me a wider track width than stock so it was fine.
-Bret 67 short-fleet sold! |
Re: 6 Bolt wheels
Center is too small. Had the exact same wheels. This is what I found. Offset looks goofy on the rear. On the front the wheel rubbed the control arm.
http://www.o-com.net/69/2.JPG
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
