Old 07-04-2006, 07:01 PM   #1
97guns
put in 5 gal. of gas and tank read 1/2 full ?
i put gas in my truck for the first time yesterday a '71 1/2 ton flletside. i read less than an 1/8 of a tank when i stopped and after putting in 5 gallons it read right at the 1/2 mark. either i have a 10 gallon gas tank or my sending unit isn't working right, does anyone know?
97guns is offline   Reply With Quote
Old 07-04-2006, 07:04 PM   #2
cdowns
cdowns's Avatar
Re: put in 5 gal. of gas and tank read 1/2 full ?
gas gauges on these trucks are not scientific instruments // a rough guide only
Old 07-04-2006, 07:15 PM   #3
wakeboarddrumma
wakeboarddrumma's Avatar
It should have settled down by now. Mine does this as well. If i run it kinda low, and put in 10 bucks, it'll say i have 3/8ths of a tank. This got me super excited one day, and so i went to arbys and came back and it was back to normal.
wakeboarddrumma is offline   Reply With Quote
Old 07-04-2006, 09:05 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I say let it get to almost empty... or even run it dry, and see how far it goes... then fill it up all the way, and see where it goes.
I've never seen 2 trucks guages work exactly the same. Mine reads a tick over empty, and it'll have 5 gallons left. I try to forget about that and treat it like a reserve.
Old 07-04-2006, 09:35 PM   #5
JAKES 68GMC
Aluminum slot wheels rule...
My truck is the same way. I went to drain the tank once, I figured it had a gallon or so in it, and it had about 8 gallons! The gauge read empty though.
JAKES 68GMC is offline   Reply With Quote
Old 07-04-2006, 09:56 PM   #6
97guns
actually that makes sense because 5 remaining gallons with the fuel gauge reading almost empty + the 5 new gallons i had put in would put it right around 1/2 tank.
Old 07-04-2006, 10:02 PM   #7
krue
Designated A-hole!
krue's Avatar
I never trust my gauge, I've run out with 1/4 tank showing.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-04-2006, 10:09 PM   #8
mbgmike
Old Ford gauges always read true. Except they stayed on Full for a long time then fell real quick and then tapered off .When it hit "E" guess what. Old chevy trucks were inconsistent. Ain't it great we have newer high tech stuff now?
mbgmike is offline   Reply With Quote
Old 07-05-2006, 11:47 PM   #9
da-burb
"Ochre Ogre"
da-burb's Avatar
mbgmike and I have owned the same Fords obviously. The first half of the tank is huge! the second half of the gague is 1/4 and then empty 20 miles later.
My 71 suburban has a half tank of gas when it hits the 1/4 tank mark. It has always been this way.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-06-2006, 12:04 AM   #10
truckdude239
truckdude239's Avatar
when mine hits emptry i still have 10 gallons in the tank lol
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-06-2006, 12:07 AM   #11
TNChevyMan
TNChevyMan's Avatar
I once had a 1/4 tank, put in $20 worth and my guage was all the way over to the 4 o'clock position.
TNChevyMan is offline   Reply With Quote
Old 07-06-2006, 09:45 AM   #12
64fleetside
Even in 87, the owner's manual stated F meant "full, but some fuel may be added" ,,E meant "empty, but fuel left as reserve". I got a 79 Ford, when it points to empty is IS empty. I have also pulled the tank on my Chevies when they shoulda been near empty only to find about 5 gals there-kinda heavy when you expect it to be lighter,,once upon a time I could fill up for $10-15,, man those were the days,,brian
64fleetside is offline   Reply With Quote
