Old 07-05-2006, 02:16 AM   #1
carl609
carl609's Avatar
disc brake swap
can I bolt 70-72 spindles, calipers, rotors onto my 67 1/2 ton to convert? what about 73 and up disc brake parts. Anyone that has done it without buying the $800 kit that can give me some info would be great. thanks
carl609 is offline   Reply With Quote
Old 07-05-2006, 02:55 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: disc brake swap
I bolted 72 spindles to my 70, I had to use the 72 balljoints, and I just used the entire steering setup off the 72, but I understand they make an adaptor so you just have to use the 72 outer tie rod ends. I also had to do some funky adapting on the brake lines, which I plan to fix using some prebent lines from a vendor.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-05-2006, 05:14 AM   #3
1972C10
1972C10's Avatar
Re: disc brake swap
ive seen people use the same lines off the drum brake just screw them into the caliper
You can put the whole front crossmember out of a 73+ Just have to drill a few holes some line up but not all six.
Im not sure of using just the spindles with your exsisting a arms.
1972C10 is offline   Reply With Quote
Old 07-05-2006, 05:29 AM   #4
krue
Designated A-hole!
krue's Avatar
Re: disc brake swap
My adapting was more at the master cylinder.
www.daveramsey.com
Old 07-05-2006, 07:48 AM   #5
bigjimzlll
bigjimzlll's Avatar
Re: disc brake swap
I recently did the swap. You will need 71-72 ball joints(easy) but you will need to adapt/rig a crossover tie rod end. 71-72 spindles take a different tie rod end/size. I welded the adjuster parts of 67 and 72 together
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
