Old 07-05-2006, 09:04 AM   #1
DREW67
DREW67's Avatar
Vin Number
Can someone decode to number for me.
CS1570CPC4690A
CE1570DPC2842A
Can you tell by the number if the bed is a stepside or fleetside?
Thanks,
Drew
DREW67
DREW67 is offline   Reply With Quote
Old 07-05-2006, 04:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Vin Number
Would that be a 71 GMC?
That VIN is somewhat close to the VIN combo for a 69, which is the only decoder I have. If it decodes like a 69, and we remove the 70 from the 5 & 6 position (which I think would be the cowl to axle measurement) then it would indicate that it is an inline powered 2 wheel drive 1/2 ton, stepside, no clue what plant P would indicate, and the rest would be sequential number... althoguh, that A on the end is an odd one to me... but GMC did some odd ball stuff with there VONs back then.
Rod would be the man to see on this one.
Rod... am I close?
Old 07-06-2006, 07:44 PM   #3
Rod
Re: Vin Number
Oh well...no other takers so I'll do it.
CS1570CPC4690A
C = Conventional cab
S = Six cyl
1 = 1/2 ton
57 = cab to rear axle dimension of 42 inches
0C = Step side box
P= pontiac Assembly Plant
C = 1967
4690 = sequence number
A = is GVW range 6000 and less
It's a 6 cyl 1967 GMC short box step side, by whats posted
CE1570DPC2842A
E = Eight cyl
1 = 1/2 ton
0D = Wide side box
C = 1967
2842 = sequence number
It's a 8 cyl 1967 GMC short box fleetside, by whats posted
That's why there is difficulty making a GMC Vin decoder, different plants did the vins differently.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-06-2006, 08:34 PM   #4
Longhorn Man
Re: Vin Number
Wow... I was way off.
I didn't even notice that the 2nd one wasn't the same as the first one.
Old 07-06-2006, 10:05 PM   #5
DREW67
DREW67's Avatar
Re: Vin Number
Thanks Rod You The Man! I love This Board
DREW67
Old 07-07-2006, 07:41 AM   #6
70GMCer
70GMCer's Avatar
Re: Vin Number
Rod....could you help me out on this one?
CE134BZ55276
thanks
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-07-2006, 08:27 AM   #7
Rod
Re: Vin Number
CE134BZ55276
C= Conventional
E= eight cyl
1 = 1/2 ton
34= wide side box
B = Baltimore assembly plant
Z = 1970 model year
rest is sequence number
It's a 70 GMC 8 cyl 1/2 ton fleetside box.
With this style vin typical to 70 and 71 GMC vins you can't tell the wheel base. That would be identified throught the model number on the glove box sticker. And for those following along....a 71 would have a number 1 instead of the letter Z in this style common to 70-71 GMC vins.
Old 07-07-2006, 10:19 AM   #8
70GMCer
70GMCer's Avatar
Re: Vin Number
Thanks Rod.....great info.......
1997 GMC Sierra Ext
1965 Mustang
