need help with replacing Harmonic Balancer
hi all, i have a 383 stroker that uses a crankshaft out of a 400 sbc (externaly balanced). my harmonic balancer cracked and i need to replace it. i was just wondering what all i need to buy in order to do the job correctly. i was talking to my uncle and he said that i will need a new balancer and a new seal as well as a new key. im not too sure what type of seal i should be getting and where exactly it goes. if someone could help me out, i would really appreciate it.
thanks, 67pro-street |
![]() Join Date: Nov 2004
Re: need help with replacing Harmonic Balancer
The seal goes on the timing chain cover. It's been a while since I've changed one, but I think it's a metal "C" channel shaped seal. They're a bit of a pain to get out, but to reinstall the new one I used a rubber hammer. You will also need a harmonic balancer puller to get the balancer off. You can get the "keys" in the help aisle of an advance or autozone or whatever, just bring the old one with you to compare. There's only a few different ones. As far as balancer, with your motor I would have no idea what to get
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
well you will need a puller and a installer..if you have never checked the t-chain..i would..and if it's a old water pump..i would be replacing that too.
may sound like a lot of money but... look at it this way...you pay someone ,you pay hundreds.. you do it your self..you get by cheaper..you have tools that last a life time, learn some thing, you don't have to repair something later..that should have been repaired before..more trust in your truck. needed.. timing chain gears and set...60.00 tops timing cover gaskets set...15.00 water pump 35.00 anti-freeze 16.00 new balance stock 55.00 tools.. balancer puller 20.00-30.00 balancer installet 35.00 p.s. you will be hard pressed to remove and install the balancer seal, with out removing the timing chain cover.. ![]() |
questions just ask ...need help just ask..p.m. me if needed...your pal mark
67-72 Addict!
Just an FYI- I bought a real nice 8" balancer- Summit brand for about $60 with the engraved timing marks and have been happy with it.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I bought a balancer last summer - and it came with several different keys - got it at NAPA
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ |
Was your motor balanced when it was at the machine shop? If so you'll need your new balancer to be the same weight as the old one.
and on a 383, it should have been balanced. You've taken quite a bit of weight from the piston/rods and the crank should have had some metal taken out of the weights. The balancer and flexplate should have been modified too.
Just make sure you get a balancer for a sbc 400 CI engine. They are externally balanced, along with the flywheel. You won't need to get anything re-balanced.
1997 GMC Sierra Ext 1965 Mustang |
#10 | |
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#11 | |
here's the pictures of the tools needed to do the job correctly first one is the remover...use three 3/8 x 3 1/2" long bolts and washers.. second is the installer...the small threaded end goes into the crank threads. the big washer and bearing sits outside the balancer and tightens down and install's it no hammering nothing damaged..it's a snap.. questions just ask..your pal mark Last edited by rage'nrat638; 07-12-2007 at 07:02 AM. |
