Old 07-05-2006, 05:49 PM   #1
bmartin9122
bmartin9122's Avatar
Question Headers for a '79 - What is the best value?
The old, ceramic headers are finally needing replacement. I have a 350ci with straight exhaust (no cats). I already have an estimate from a local shop. They want $500 for ceramic headers (don't know the brand) and installation. This sounds incredibly cheap. Am I getting junk? Should I just go back to a manifold/downpipe set-up? The shop says I will only lose about 5% of my power, but gain alot of reliability. They say manifold bolts won't come loose like they do on headers.
Opinions?
79 GMC Sierra Grande K15
--PPG paint code 62608 Sunburst Orange Metallic (WA802K)
--Gentex auto-dimming rearview mirror model K31
--Carriage Works billet grille model 40071
--Go Industries 2.5" tubular stainless headache rack
--Sylvania Silverstar sealed headlights model H6024ST
--Texas Saddlebags center console model 101
--Brown's Welding class IV V-5 pipe bumper
--Ramsey RE8000 winch
--33" tires
bmartin9122 is offline   Reply With Quote
Old 07-06-2006, 08:23 AM   #2
Jim85IROC
Jim85IROC's Avatar
Re: Headers for a '79 - What is the best value?
You could get locking bolts and copper gaskets for the headers if you don't want to snug them periodically.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 07-06-2006, 09:17 AM   #3
bmartin9122
Thank you for the response!
Is that a common practice?
For the price the shop is quoting me, am I better off with a standard manifold set-up? I am not looking for big power as much as I want the truck to be relatively troublefree. I understand mechanics, but I am no wrench.
--33" tires
Old 07-06-2006, 09:32 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
If your goal is purely reliability, you might consider manifolds over headers. It isn't the popular setup here on the board, but manifolds require no maintenance. My engine is stock, and I run manifolds for this reason.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-06-2006, 10:07 AM   #5
bmartin9122
Sounds good. This old truck has enough problems without me adding fuel to the fire. Headers sound nice, and I know they add power, but I intend to use this truck. I don't want to have to check the oil, P/S, brakes, coolant, washer, AND tighten the headers. LOL! I guess I am lazy, but I really just want the truck to run well without constant babying.
Are there any manifolds you guys would recommend, or just get the OEM? The shop had suggested trying to find some junk yard parts. Also, the engine is bored over 0.030" (not my doing) and has a new 600cfm Edelbrock carb, so would the choice in manifolds change for these reasons?
--33" tires
Old 07-06-2006, 12:44 PM   #6
Slonaker
Slonaker's Avatar
The popular factory manifolds are rams horns, like what came on older corvettes. They were installed on a lot of vehicles, but the corvette ones (2.5" I think) are the ones everyone wants.
Some folks have reported having to notch their motor mounts to get them to clear, but N2TRUX didn't have any problems when he installed them on his truck.
I have looked at some of the non-corvette ones lately at swap meets. The seem to go for about $50 per pair, and usually need new studs.
The easiest thing to do would be to just get a set off a similar pickup in a junkyard. That way you know they will fit.
Slonaker
Stock '01 Silverado
Old 07-06-2006, 01:03 PM   #7
bmartin9122
I assume you are talking about these:
http://www.gmgoodwrench.com/perfpart...406&section=ep
I talked to the shop manager, and he said you can't even find them anymore. Apparently they are quite rare, and nobody has decided to make a knock-off version. He said I would pay quite a premium to get these. Oh well.
--33" tires
Old 07-06-2006, 03:02 PM   #8
Slonaker
Slonaker's Avatar
Those are the corvette ones, and they are being reproduced. You can even get them without the mount for the alternator or PS pump or whatever it is.
http://www.classicchevy.com/product....JQRJ9158H3D1S0
The easiest solution, as I said before, is just to go back to stock.
Slonaker
Stock '01 Silverado
Old 07-06-2006, 04:09 PM   #9
bmartin9122
I was looking at this site. They appear to have good products. Might you suggest someone else?
http://www.autopn.com/autoparts/look...72&AUTOPN_ID=6
--33" tires
Old 07-06-2006, 06:03 PM   #10
Slonaker
Slonaker's Avatar
I was thinking junkyard or swapmeet if that tells you anything about my budget.
Most people want to replace manifolds with headers, so I would expect it to be pretty easy to find a decent used pair.
Slonaker
Stock '01 Silverado
Old 07-10-2006, 01:20 PM   #11
Jim85IROC
Jim85IROC's Avatar
I really don't see this reliability issue with headers that people keep mentioning. I've had them on my Camaro for years, and other than a periodic re-tightening, I've never had a problem. I put them on the car sometime around 99, and since then, I've probably retightened a couple bolts 3 times, each time it took me longer to get the wrench.
454
TH400
My Sounddomain Page
