Turn signal acting weird w/van tilt.
The emergency flashers work fine. However, the actual turn signals are doing weird things. I just installed the tilt out of a 79 van. All worked great with non tilt column. When I turn on the turnsignal, the bulb lights very, very dim and then will flash brighter, but will take 2-3 seconds between flashes. I feel it is probably the switch.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
Re: Turn signal acting weird w/van tilt.
try taking the connectors apart and spraying both halves with contact cleaner and see if that helps
A lot of the van columns come from WORK vans with lots of use and abuse. Many of them are covered with ashes, spilled drinks - soda,beer,coffee,etc. Try using an air hose to clean out the contacts.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
