Active Member
Cleaning aluminum
I just bought a used fast burn 385 GM crate motor, the heads are pretty dirty however i dont want to take the entire engine apart just to bead blast them or something, any ideas on cleaning them, Carb cleaner or something. Thanks
![]() Join Date: Oct 2005
Re: Cleaning aluminum
Small stiff bristle brush with some Laquer thinner or some other strong solvent and patience.
and a good breeze coming through your work area! don't want anyone passing out or ummm working in a really good mood ha ha
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
Use Gibbs Lubricant, go to Roadsters.com and find an article on it there
Aluma-Brite aluminum cleaner. Find it at your local HVAC supply house.
pressure wash with soap and water i like makeing a strong solution of spic-n-span and water to run thru my pressure washer
Try aluminum wheel cleaner from Eagle One cleaners. There is one in particular that has a picture on the front of the bottle of an old style "hurricane wheel". That should clean all of your aluminum right up.
ZEP makes a product called aluma-brite this is what is used to clean trailers, alum wheels,...if you can get ahold of some of this stuff your problem is solved.
i bought 4 one gallon jugs...it works great !!!! Last edited by rage'nrat638; 07-06-2006 at 09:41 PM. |
go to ur local detail shop and ask to buy some acid based wheel cleaner, it will clean damn near ne thing, just make sure ur in a well venelated area
