Old 07-06-2006, 04:32 PM   #1
fade94
fade94's Avatar
Info and Pic request. Fuel cell plumbing.
I have a fuel cell (plastic) that came with a parts truck. Cell is new but does not have the fittings with it. I think the outlet is -8 and the vent or return is -6. I have never dealt with AN fittings before. Can someone post up a pic of how to hook up to the cell AND tie into the stock fuel line? This is on my 71 C/10 w/350. I am running a mechanical pump. ANY and ALL info would be greatly appreciated. Also, let me know where you put the cell. I thought about under the bed, but I'm not sure how safe it would be back there being plastic.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 07-06-2006, 05:14 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Info and Pic request. Fuel cell plumbing.
You should be able to get a -8 compression fitting to go to the fuel cell, then run enough hard line to where you need to tie into the factory hard line, then use another compression fitting with a barbed hose fitting. Or, you could just flair the end of the hard line ran from the tank and slip the rubber hose over it. The flair, along with the hose clamp, would keep it from slipping off.
Or, put a fitting on the stock line and flair it. Then have a hose made up with the -8 on one end, and a matching fitting to the one installed on the factory line put on the other end.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
