Old 07-06-2006, 07:21 PM   #1
76bonanza
76bonanza's Avatar
new fans from WES at classic heartbeat
I installed a set of the fans from classic and a radiator cover here are some pics so far I love em and Wes is a good guy to deal with.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-06-2006, 07:58 PM   #2
Sweet72
Sweet72's Avatar
Re: new fans from WES at classic heartbeat
Looks good there Bonanza, where did you install the control thermostat? What temp does it come on and go off?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-06-2006, 08:08 PM   #3
76bonanza
76bonanza's Avatar
next to the radiator by the washer bottle on that post. Not sure what temp it comes on I set it to come on when the engine got to about 190 deg. Running a 195 thermostat.
1968 c10
lowered 3" 4"
Old 07-06-2006, 08:26 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Nice job!. Your engine bay looks awesome!!!!!!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-07-2006, 09:46 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Very nice!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-07-2006, 10:24 AM   #6
68 short step
what did all that set you back>?
68 short step is offline   Reply With Quote
Old 07-07-2006, 10:51 AM   #7
76bonanza
76bonanza's Avatar
I think the fan setup was like 350.00 and the rad cover was like 50.00. well worth the money for the fit, took like 2 hours to install very easy and looks factory.
1968 c10
lowered 3" 4"
