Old 07-07-2006, 06:19 AM   #1
freebird
Active Member
freebird's Avatar
Sagging Question
67 GMC 305E much abused truck with a sag to the drivers side.... Do you think this is from weak springs or shocks... Thinking of replacing both ,,,, What else should I be on the look out for Thanks...
67 GMC 305E V-6
(Old Blue)
Rust In Progress (RIP)
85 Harley FXRS
(Baby Blue)
MEMBER OF THE DRUM BRAKE CLUB
freebird is offline   Reply With Quote
Old 07-07-2006, 08:01 AM   #2
Sweet72
Sweet72's Avatar
Re: Sagging Question
I think you answered your own question. C1500? Truck unloaded, measure the distance from the rear axle tube to a reference point on the frame on both pass and driver sides. I doubt the leaf springs are unevenly "sprung". Could be a front coil also. Only way to determine what's out of whack is get under there and start measuring. Are the body mount rubber bushings rotted and causing the cab/front clip to sag? If so, the bed will be level w/ground and cab will be off-kilter.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-07-2006, 09:51 AM   #3
Putter
More Cowbell....
Putter's Avatar
Glad this is about springs. Just reading the title, I assumed you were bashing the little lady....but those can be repaired also.....so either way, we got you covered.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-07-2006, 03:38 PM   #4
freebird
Active Member
freebird's Avatar
Just when you look at it from the front the drivers side is down lower... Whats the best place to measure to....
67 GMC 305E V-6
(Old Blue)
85 Harley FXRS
(Baby Blue)
