Old 07-07-2006, 10:27 AM   #1
stynchrr
stynchrr's Avatar
Front shock stud repair help
I got a 72 1/2 ton 2wd and the one upper shock stud must of been loose for quite sometime. It has rounded out the mounting hole in the frame to the point where i could just pull it out. I was planning on welding a washer or something to repair the frame and replacing the stud. Is that a good idea and is there any place that sells the upper front shock studs?
stynchrr is offline   Reply With Quote
Old 07-07-2006, 02:30 PM   #2
cdowns
cdowns's Avatar
Re: Front shock stud repair help
speedway motors sells shock studs// i welded a 2inch dia 3/16 thick washer(made it myself with a hole saw) to the inside of the frame rail for this problem
Old 07-07-2006, 02:35 PM   #3
stynchrr
stynchrr's Avatar
Thanks for the reply. I am glad i decided to buy a welder before getting into this project.
