Old 07-07-2006, 01:02 PM   #1
tkeduk8r
tkeduk8r's Avatar
what 283???
Ive got acess to a few old 283's laying around... all are two bbls, mostly complete, from appx 58-68 vintage... if im looking for the best to build ( iknow for a 350 a 010 block, etc.) for a little performance, but mostly to bolt in front of a A833 four speed/od for reliability and fuel economy (im getting alomost 20 mpg out of a 305/2004r) but it would be fun to go back to rowing the gears!!!... any suggestions for the old 283??? OHHHHH and how do i tell difference externally tween a 327 and 283??? thanks for all the help!!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 07-07-2006, 06:43 PM   #2
larry may
Re: what 283???
Good question Same block casting numbers were used on both.Should be a number stamped on the right front of the block where the head meets. This number may tell the difference. Sometimes there was decals on the valve covers that indicated cid. NOT 100% true identification either. Good luck
larry may is offline   Reply With Quote
