Old 07-07-2006, 02:57 PM   #1
lost wages
lost wages's Avatar
454 valve covers
in my 68, will i be able to run a tall valve cover on a big block? its going to be sitting on the 67-71 style bb mounts. any problems with firewall or booster? Im wanting to do roller rockers on this engine but not sure if there is room, thanks.
lost wages is offline   Reply With Quote
Old 07-07-2006, 04:52 PM   #2
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Re: 454 valve covers
Mine just barely clear, and the breather will only fit on the front.
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 07-08-2006, 12:30 AM   #3
corn
My 69 has the stock mounts & the big booster & I had tall chromes on it with no problems...
corn is offline   Reply With Quote
Old 07-08-2006, 08:50 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Its going to be close. (steel will give you more clearance.) Ive got fabbed aluminum and will have to clearance the drivers side at the firewall about 1/2".
Tom Vogel is offline   Reply With Quote
