07-07-2006, 06:35 PM | #1 |
Tire size question, for non lowered truck
I have a '67 2wd that has BFG radial T/A's on it. I am tired of dragging the ground over rocks, or getting stuck on curbs, etc. So, I would like to put some larger truck tires on it, but I don't know what size would fit and look good too. I will use 15" or 16" wheels, and was thinking of something in the 29"or 30" neighborhood. I am not adverse to putting in the 3/4 ton springs, or making slight mods to make it work, but I don't plan on going overboard to stuff 35s in. Does any body have some pictures of trucks set up this way?
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold Last edited by walker; 07-07-2006 at 06:36 PM. |
07-07-2006, 09:15 PM | #2 |
Re: Tire size question, for non lowered truck
235/75r15 is the size closest to stock tire size
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-07-2006, 10:15 PM | #3 |
Gone Fishing
Run some 31 x 10.50 x 15 on it. they fill the wheel well up and look pretty good on theese trucks.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 Last edited by jsbgump; 07-07-2006 at 10:15 PM. |
07-07-2006, 10:49 PM | #4 |
Epoxy Primer Friendly
"I am tired of dragging the ground" How low is yor truck ? Current tire size ?
07-07-2006, 11:02 PM | #5 |
For stock height I always use 255/70/15 T/A's. Front tires in this pic are 255's, back are stock 235's.
"You can take the man out of PA, but you can't take PA out of the man" |
07-07-2006, 11:25 PM | #6 |
i would recomend the 235/75r15 i got a book at work called old timers fitment guide and it translates most stock 15 inch wheels to the 235/75r15 only reason i recomend it is it get the speedo the closest to being right plus you have a lot more options tire wise to pick from just my $.02
07-07-2006, 11:30 PM | #7 |
heres mine with 285/70/15's on all corners
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
07-08-2006, 11:28 AM | #8 |
Mine looks about like Heavy ds. The problem is that it is pretty rugged terain out here. The other problem is when I eithher get it loaded up, or have a trailer attached, I tend to bottom on the culvert at the end of my driveway.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
07-08-2006, 04:39 PM | #9 |
Here is my C10 with 31X10.5X15. Wheels are 8X15. They are Goodyear HT.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
07-08-2006, 05:03 PM | #10 |
Looks like 31 10.5 15s it is. 1 70PU, have you had any rubbing/bottoming out problems after you put them on?
07-08-2006, 06:34 PM | #11 |
Do the Dew!
Mine also has the height of HeavyD's, but I am running 255/65r15 back and 245-65r15 up front. Stock height tires with a wider tread pattern.
07-08-2006, 08:16 PM | #12 |
No rubbing or anything.
07-09-2006, 12:32 AM | #13 |
I finally went out and looked at my tire size. Right now they are 255/70/15s. They just seem a bit small to me.
07-09-2006, 10:38 AM | #14 |
man i run 275/60/15s they look great and fill the rear wheel well. i think you could even go biger like 295/60/15s..
