Old 07-08-2006, 11:00 AM   #1
skillet
skillet's Avatar
Roch carb fuel wells
I would like to seal the fuel wells on my Roch carb with something other than epoxy. Has anyone ever used 50/50 solder to seal them or would you have to use silfoss? Thanks very much for any info.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 07-08-2006, 11:30 AM   #2
neonlarry
neonlarry's Avatar
Re: Roch carb fuel wells
I don't think you will have much luck getting the solder to stick well enough.Might try TIG but thats overkill why not just tap them and locktite a plug in.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-08-2006, 11:36 AM   #3
skillet
skillet's Avatar
That's a good idea. I quess the threaded plug would just need to be flush like the fuel well plugs for clearance purposes.
Old 07-08-2006, 12:37 PM   #4
rage'nrat638
rage'nrat638's Avatar
jb weld..why make a mountain out of a mole hill
rage'nrat638 is offline   Reply With Quote
Old 07-08-2006, 01:33 PM   #5
skillet
skillet's Avatar
JB Weld was what I used a few months ago and before that Devcon 5 minute epoxy. But alas, the gas leak smell has returned, hence the question.
Old 07-08-2006, 02:53 PM   #6
neonlarry
neonlarry's Avatar
Yeah I was thinking of a recessed allen head screw.
Old 07-10-2006, 12:24 AM   #7
jimfulco
I'd be afraid the heat of soldering would melt the carb metal.
jimfulco is offline   Reply With Quote
