Old 07-08-2006, 02:05 PM   #1
mgranta
Can anybody tell me what this is???
What is this? and do I need it?
mgranta is offline   Reply With Quote
Old 07-08-2006, 03:03 PM   #2
72CSTC5
72CSTC5's Avatar
Re: Can anybody tell me what this is???
Do you have a/c on your truck?
72CSTC5 is offline   Reply With Quote
Old 07-08-2006, 03:30 PM   #3
mgranta
nope no AC. one of the lines goes to the dizzy and the other two to the carb. There also seems to be some electrical hook up to it.
Old 07-08-2006, 04:26 PM   #4
stope4
Looks like TCS. (Transmission Spark Control) I do not believe it's really needed with today's gasolines.
stope4 is offline   Reply With Quote
Old 07-08-2006, 05:56 PM   #5
kwmech
TCS lets the vac advance work when the truck gets shifted into high gear. Supposed to drop the NOx content of the exhaust. First attempt at todays EGR system
Old 07-08-2006, 08:23 PM   #6
mgranta
I knew you guys would know! So off it comes!!! Thanks for your help!
Old 07-08-2006, 09:09 PM   #7
Sweet72
Sweet72's Avatar
TCS (temperature/transmission controlled spark) solenoid. If it's hooked to the distributor vacuum advance. Like kwmech said it allows vac advance if engine temp is above 82*F or transmission is in high gear. Wire should hook up to it's own temp sender on cyl. head and transmission.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
