Old 07-08-2006, 02:54 PM   #1
70GMCer
70GMCer's Avatar
Amp Gauge ?
I'm trying to get my factory amp gauge to work. I've tried 2 different factory gauges, and no luck. I have did a continuity check on the circuit from the battery junction block to the dash panel plug (both fuses are good). All checks out good. I have a constant 12 volts into the gauge and out the other side of the gauge whether the engine is running or not. Is this supposed to have constant 12 volts there? Does anyone know what the ohm readings are supposed to be across the amp gauge terminals?
Any other ideas?
Oh, I did rewire my alternator for a internal regulator per FAQ on here. Charging system is working fine.
steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-08-2006, 05:24 PM   #2
jhow66
jhow66's Avatar
Re: Amp Gauge ?
Check this:
http://67-72chevytrucks.com/vboard/s...ighlight=gauge
It will show you the wire that was lost when you went to internal reg.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-08-2006, 06:34 PM   #3
cornutz
All Praise RANDY!!
cornutz's Avatar
Re: Amp Gauge ?
quick side question Steve,
Which alt. did you use?
Thanks,
cornutz is offline   Reply With Quote
Old 07-08-2006, 06:37 PM   #4
70GMCer
70GMCer's Avatar
Re: Amp Gauge ?
Just a regular 60 amp w/internal reg. Not a one wire alt.
1997 GMC Sierra Ext
1965 Mustang
Old 07-08-2006, 11:55 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Amp Gauge ?
Here is a link that shows how to wire an ammeter in for a 66.It should be the same.
http://www.6066gmcguy.org/ammeter.htm
To answer your second question.
http://67-72chevytrucks.com/vboard/s...d.php?t=178329
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-09-2006, 12:44 AM   #6
MisterMan
MisterMan's Avatar
Re: Amp Gauge ?
pop off ur dash bezel WITH THE NEGITIVE OFF THE BATTERY REMOVED. have some one hold the dash (to keep it from grounding.) re connect battery. get a tester on the back of the amp gauge, positive on one post, ground the other. need more info, pm me.
trust me, that gauge is hot 24/7 (as long as the batt is connected) i fried my brand new circut board by letting the post's ground out on the frame while putting the dash back in.
MisterMan is offline   Reply With Quote
Old 07-09-2006, 07:57 AM   #7
70GMCer
70GMCer's Avatar
Re: Amp Gauge ?
Thanks to all for those ideas. From what I have been reading on here and elsewhere, is to go with a volt meter instead. I'll try a few of those other ideas mentioned, and then see.
1997 GMC Sierra Ext
1965 Mustang
