Old 07-08-2006, 04:12 PM   #1
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Was 4WD an option in 1963 or 64?
I'm considering buying a 1963 or 64 GMC 3/4 ton supposedly with the original V-6 and 4wd.
Was this available then? What transfer case was used if it was?
Thanks,
Nate
1971 Blazer CST SOLD!
71Blazer is offline   Reply With Quote
Old 07-08-2006, 04:46 PM   #2
Jeffs65GMC
4 headlights > 2
Jeffs65GMC's Avatar
Re: Was 4WD an option in 1963 or 64?
From what I understand, it was...kinda. It was a dealer installed option. IIRC, it used a rockwell t-case, but I'm not positive on that one.
1965 GMC 1000 fleetside (for sale)
1989 Jeep Wrangler (currently torn down, will return again)
1998 Jeep Cherokee (daily driver)
Jeffs65GMC is offline   Reply With Quote
Old 07-08-2006, 04:50 PM   #3
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Thanks for the reply... anything in particular to be aware of with these model years? Typical rust spots or mechanical issues, etc?
Old 07-08-2006, 04:54 PM   #4
Jeffs65GMC
4 headlights > 2
Jeffs65GMC's Avatar
Can't speak from much experience, but on my fairly rust free 65, it had a bit of rust on the rear of the top of the cab (where it angles back out), one rocker, and one cab corner. Cab corners and rockers are gonna be an issue in any truck, along with door bottoms, fenders, etc. Anything can be fixed with some sheetmetal and a welder, so don't be scared away if it's mostly solid.
Old 07-08-2006, 08:15 PM   #5
littlee_domn8r
AKA "Hurricane Hank"
littlee_domn8r's Avatar
Usual rust spots are fenders, rockers, cab corners, drip rail. pretty much the same as the newer ones! I've also heard some horror stories about the area around the windshield being rusted away.
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt
"They say hard work never killed anyone, But why take a chance?
63 GMC C10 Custom LWB 355/350 AT
00 Chevy Silverado 1500 base V6/AT
07 Chevy Monte Carlo SS 5.3 V8
littlee_domn8r is offline   Reply With Quote
Old 07-08-2006, 08:18 PM   #6
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Many thanks, I'm going to check it out now...
Old 07-08-2006, 09:07 PM   #7
b454rat
GM started to make their own 4wds in 60 or 61, so a 63 would be a factory truck. On 63s, the wrap around windsheild posts can get rusty, but other than that, it's the same as any other truck, floors, door bottoms, rockers, cab corners, fender bottoms, etc.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-08-2006, 09:46 PM   #8
Frizzle Fry
Frizzle Fry's Avatar
Most 60-66s I've seen have some level of rust under the battery effecting the pass-side inner fender and the lower corner of the core-support.
Frizzle Fry is offline   Reply With Quote
Old 07-08-2006, 11:52 PM   #9
mbgmike
yeah from what i remember it was about the 63's that 4wd was offered from the factory. it wasn't a dealer installed option. I think thats when they came up with the "k" designation for 4wd. ALot of Ohio farmers had them as well as 63 Ford 4wd's I know they had 4wd's in the late 50's but not sure it was a production truck. Might have been.
mbgmike is offline   Reply With Quote
