Old 07-08-2006, 05:40 PM   #1
72str8flush
72str8flush's Avatar
Installing a new brake booster
I am installing a power brake booster on my previously manual truck. I got it all tightened down and everything... but it the pedal sticks at the bottom of the floor when depressed... you have to pull it back up after pushing it in. Can anyone help me on what is going on here and what i need to do to fix it. Thanks.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 07-08-2006, 06:20 PM   #2
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
Re: Installing a new brake booster
Did you reinstall the pedal return spring?
mtndewmaniac66 is offline   Reply With Quote
Old 07-08-2006, 06:30 PM   #3
72str8flush
its on there... do i need a more bulky one for the pb? or could it be a vaccuum issue?
2006 VW GTI
Old 07-08-2006, 06:47 PM   #4
mtndewmaniac66
Do the Dew!
It wouldn't be a vaccuum issue, sounds more mechanical though. Check for binding. How about the pushrod? is it clean, free from contamination? Straight and not bent? Did you also check to see if the bolt is too tight on the swingarm mount? The swingarm, or pedal arm, should move freely.
Old 07-08-2006, 07:44 PM   #5
rage'nrat638
rage'nrat638's Avatar
are these parts you installed new?
could be any number of things if not..
the pedal rod is different for power brakes vs manual brakes
the rod between the booster and master needs to be the correct length.
did you bench bleed the master cyl? checking it's operation ?
we need details here!!!
rage'nrat638 is offline   Reply With Quote
Old 07-08-2006, 10:38 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've had a bum booster do this.
Old 07-09-2006, 05:11 PM   #7
72str8flush
I pretty much followed this FAQ: http://67-72chevytrucks.com/vboard/s...d.php?t=163387
I switched the pushrod to the other side of the pedal because i couldn't get it in otherwise. I think this maybe my problem.... Hopefully.
2006 VW GTI
