Old 07-08-2006, 09:10 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Bass ackwards booster Q...
OK, I've never really followed along on all the 'how do i install a booster' threads, and after a search, I know nothing more than I did 10 min ago. (Does anyone have good luck with the search, I NEVER get what i am looking for, even if I put in the actual name of the thread)
Anyways, I have power brakes, and a messed up booster. I'm sick of getting used ones that are either blown from the get go, or blow out a few months later. (Always a bad sign when you get one and pour the brake fluid out of it on the floor when you unpack it.) And if you've priced a new one.... screw that. It blows the Mc Budget.
So, what does it take to get rid of the stupid thing all together? I know the master cylinder has the same part number for power, and non power... So I'm good there.
Am I able to flex and manuver the brake lines enough to do it, or will i be getting out my brake line kinker?
What else is there. I remember something about mocing the rod on the pedal, can this be done with the parts that are on my truck right now?
I've had a truck with manual brakes, and IMO, it wasn't all that bad. I was able to flat spot the tires at will, and there was no "ugly booster" to look at. Plus, never had any booster issues with that one either...for obviouse reasons.
Don't try and sell me a booster, onless it is a remaned unit that you got 2 years ago, has no fluid in it, and are willing to part with it for 50 bucks.
Didn't think so.
So, what's the steps, and do I need any parts to remove this worthles option.
Old 07-08-2006, 09:24 PM   #2
TugOwar
Re: Bass ackwards booster Q...
I seldom get what I need from the search either Andy.
I drove my 66 1/2 ton all over hell and creation for 12 years with manual brakes. I like my power brakes but I get what you're sayin, they're not absolutely necessary.
I can't help with the conversion question but I think we (the board) should put our heads together and figure out how to rebuild boosters ourselves. There can't be that much to them.
TugOwar is offline   Reply With Quote
Old 07-08-2006, 09:25 PM   #3
Sweet72
Sweet72's Avatar
I'm almost positive you'll need a different pushrod. I was able to make my non pwr lines work with the booster installed, but they were a bit shorter than I would like em, so going the other way you should have plenty of line to work with. Yea, the used boosters really blow! I had two go out in a years time.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-08-2006, 09:28 PM   #4
Longhorn Man
I'm on #3, and it hasn't even been on the road for a year.
Hmmm, a new push rod.
I'm guessing they are a dime a dozen on the parts board, with everyone installing boosters...
Would the one ton use the same one as the 1/2 ton?
Old 07-08-2006, 09:31 PM   #5
Sweet72
Sweet72's Avatar
Good idea Tug O War. I have a '72 overhaul manual that outlines a step by step rebuild if you have all the fancy GM "J" tools, but I could make them since they're pretty simple tools. I looked on the web for a source for the diaphrams with no luck.
Old 07-08-2006, 10:03 PM   #6
TugOwar
Maybe I'll talk to my parts guy at Gonzalez and see if he can find a source.
Sam, maybe if you have the time and means you could scan and post the pages from that manual.
Old 07-08-2006, 10:12 PM   #7
mister.freeze
mister.freeze's Avatar
I chunked it all and went with hydroboost. It really wasn't too tough. I think I used a '96 3/4 ton setup from the local parts store. I can help if you go this route.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 07-08-2006, 10:19 PM   #8
Longhorn Man
that kinda goes against the whole $50 Mc Budget thing.
Honestly, I have never driven a Hydroboost where I liked the pedal feel. That's also one of the problems I've always had with power brakes too, the 'feel' is gone.
Old 07-09-2006, 02:53 AM   #9
72CSTC5
72CSTC5's Avatar
Nuts driving with non power brakes. Like everything else, as time progresses so does technology. Dont be lazy and install the power brakes to your ride.
72CSTC5 is offline   Reply With Quote
Old 07-09-2006, 02:57 AM   #10
pritch
pritch's Avatar
Seems like you need a longer pushrod to convert from non-power to power, maybe you could just shorten the PB pushrod...Or maybe we could trade, I'm converting to PB in a couple months.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 07-09-2006, 05:16 AM   #11
krue
Designated A-hole!
krue's Avatar
The manual pushrod is rounded on the end that goes into the m/c. The power pushrod has an eye on either end. They are both adjustable IIRC.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-09-2006, 07:41 AM   #12
70GMCer
70GMCer's Avatar
does this help?
http://67-72chevytrucks.com/vboard/s...d.php?t=163387
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-09-2006, 08:16 AM   #13
Solver
Solver's Avatar
Andy the last 2 boosters I got from oreilly's were $89 for just the booster and $99 for booster and new master cylinder. Might want to check that out before you drop anymore change on a questionable used booster!
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 07-09-2006, 10:46 AM   #14
Longhorn Man
Lazy has nothing to do with it, lazy would just replace the booster instead of swapping to manual. It would be quicker and easier, to simply swap the booster out than to convert to manual brakes.
I would love to swap, and to help you out as you are helping me... but this is my daily driver (only vehicle)... I can't have it down for a couple days waiting on the mail man to bring the the rod.
Krue, good info.
70GMCer, awsome link. Step by step, awsome.
Interesting.
Now, it has been a couple years, but, last time I checked, they wasnted more like 180 for the booster I needed. I'm wondering if the daul diafram, drum drum, is that much more than the 1/2 ton disk/drum parts. I guess I need to look around. I honestly haven't bothered since I got sticker shock a few years ago.
Old 07-09-2006, 11:32 AM   #15
da-burb
"Ochre Ogre"
da-burb's Avatar
Less than 2 years ago a rebuilt dual diaphram booster from NAPA was $85. The core charge was $2. NAPA also had the booster rebuild kits. I was looking for the rubber boot on the back of the booster and that was the only place I could find that boot, it wasn't sold seperately.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-09-2006, 11:55 AM   #16
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Andy - PM me your address. I have a non-power rod that I will send you. I don't need it.
Should be able to armstrong the brake lines. I wonder about the proportioning valve? Will you need to replace it with a manual brake distribution block, or whatever they are called for manual brakes?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-09-2006, 12:40 PM   #17
neonlarry
neonlarry's Avatar
P-Valve is the same
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-09-2006, 03:30 PM   #18
Sweet72
Sweet72's Avatar
Tug O War, I don't have access to a scanner. I checked napaonline for the 3/4 ton dual diaphram is $119 and $28 core charge. Couldn't find any rebuild parts on the site... Sorry for jacking your thread Andy.
Old 07-09-2006, 03:45 PM   #19
wibilly
wibilly's Avatar
personaly i don't want any vehicle without power brakes. i guess i've gotten so used to them that without it seems like no brakes to me
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-09-2006, 04:01 PM   #20
TugOwar
Yes Andy, sorry bout that bro.
Old 07-09-2006, 06:53 PM   #21
Longhorn Man
Don't mention it... you guys are keeping it on track. If you came up with the stuff to fix it... I'd jump on your band wagon in a heartbeat. I like the low pedal, the lazy man pedal pressures... just refuse to buy another used booster, and can't afford (or won't afford anyways) a new one.
Your thread jacking is better than some of the other responses... saying I'm lazy and technology has advanced...I guess I may as well install day time driving lights, air bags, and ABS...along with a million warning stickers.
Glock... PM is on the way... This is very much apreciated. I will swap over to non power brakes, and later on down the road when i have the money to spare... or I can budget it into my life, I'll get a new one.
