Old 07-09-2006, 04:59 PM   #1
ronr
After market tach...question
I want to hook up a sun super tach to my 350 which has an accel hei
distributor. Do I need a special connector at the distributor? And exactly which port on the distributor does it go to(a description would be greatly appreciated) Thanks Ron
ronr is offline   Reply With Quote
Old 07-09-2006, 05:21 PM   #2
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
Re: After market tach...question
hope this helps
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 07-09-2006, 05:39 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
it should say TACH above the connecion pictured above. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 07-09-2006, 05:57 PM   #4
1972C10
1972C10's Avatar
You can use a regular female spade connector but it wont retain itself as well as one of these http://www.ecklers.com/product.asp?p...dept%5Fid=1783
And in case you need the bat side http://www.ecklers.com/product.asp?p...dept%5Fid=1783
1972C10 is offline   Reply With Quote
Old 07-09-2006, 06:46 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
I have used one for years and never had a problem, spade connector that is.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-09-2006, 07:10 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
same here, I've ran a spaid connector for almost a decade with zero issues.
Old 07-09-2006, 07:55 PM   #7
Igotachevyor2
Apache Club
me too
Old 07-09-2006, 09:08 PM   #8
ronr
Thanks to all, aint this forum great..........
