07-11-2006, 12:03 AM | #1 |
Truckin' Krazy
parting 71 swb 4x4 AZ
This truck rolled hard, front frame is toast, maybe there's some rear frame stuff someone needs, decent interior. it was a one owner truck before this happened. Will be taking it apart on wed & thursday this week. Tom 480-241-1318
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
07-11-2006, 12:33 AM | #2 |
Re: parting 71 swb 4x4 AZ
AC truck? How much for the compressor brackets? Also interested in the crank pullies. Maybe the left side door hinges, if they look OK. Shoot me some prices.
Thanks, Brett |
07-11-2006, 06:21 AM | #3 |
What a shame.
07-11-2006, 02:52 PM | #4 |
I might be interest in the transfer case cross member if it servived, any of the A/C stuff from under the hood, Evaperator & box, TEV, brackets, the tranfercase shifter if it's crome. Top alt bracket. ( The sloted arm )
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 07-11-2006 at 02:54 PM. |
07-11-2006, 03:15 PM | #5 |
What does it have as far as guages, column, etc?
1986 C10 - LWB, 305/700r4, posi, vortec heads |
07-11-2006, 07:09 PM | #6 |
Is the crome trim that divides the two colors still good? If so name a price.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
07-12-2006, 12:32 AM | #7 |
Truckin' Krazy
Non tilt auto column, no tach dash. Bowtieman what chrome piece are you referring to? The rest of the parts I'll check on tomorrow & let you know whats good & what isn't & will try to post better pics after pulling parts. Thanks, Tom
07-12-2006, 10:54 AM | #8 |
Active Member
PM sent........thanks Rick
07-12-2006, 10:46 PM | #9 |
I'm interested in the cross member that sits between the forward spring hagers on the rear axle. Also all 4 of the rear spring hangers.
It you are taking the box off, I would like to see some pics to make sure the cross member and hangers are the same as mine.
Eric 1969 K20, 465/205 package |
07-13-2006, 12:16 AM | #10 |
Truckin' Krazy
Still tearing down, Dont have pics yet, I'm roasting in the hot desert sun. I'll have pics & prices tomorrow. Heavy K what cross member do you need? Custom 10, crossmember looks good,Whats TEV?Tranfercase shifter isn't chrome. Dirtball ac brackets all there & good, crank pully good, hinges good,pics tomorrow
07-13-2006, 07:17 AM | #11 |
TEV ( Thermostatic Expansion Valve ) it's the valve that controls the flow of refrigerant going into the evaperator or "cooling coil". If you can get some Pic's of the a/c box, TEV, and the crossmember once you get things disassembled.
Stay cool ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
07-13-2006, 11:09 AM | #12 |
The cross member mounts directly between the forward spring hangers on the rear axle. It is located behind the cab and ahead of the rear axle. The main piece of the cross member mounts to upper part of the frame rail and there are some gussets that connect the cross member to the lower part of the frame rail.
I need the cross member and the gussets
07-13-2006, 07:42 PM | #13 |
I would be interested in the wiring harness if it is uncut. Give me a price + shipping to 96349. This is a FPO AP U.S. military address. Thanks--David
07-13-2006, 08:42 PM | #14 |
Truckin' Krazy
Heavy k heres some pics, Kantosensei what part of wiring harness? Pms sent
07-13-2006, 08:44 PM | #15 |
Truckin' Krazy
more pics
07-13-2006, 08:48 PM | #16 |
Truckin' Krazy
OK heres some more pics, dirtball has dibs on the ac brackets & pullys. Thanks, Tom
07-13-2006, 08:54 PM | #17 |
The underdash wiring harness, fusebox, connectors, etc etc. Mine has been chopped, spliced with different color wires and engineered so much that I cant figure out what wire goes where.
07-14-2006, 07:26 AM | #18 |
It's tuff to tell from the pic's what shape the parts are in. Is that dirt or rust on the transfere case crossmember, and is there any damage to the a/c evap. box tubes and coil ?? Give me your best discription and prices and will go from there.
Gary Also it looks like dirtball is passing on the a/c brackets & pullies I might be interested.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 07-14-2006 at 11:12 AM. |
07-14-2006, 08:59 AM | #19 |
Hey guys, I have to pass on the AC brackets and the pullies this time. Who else needs 'em?
07-14-2006, 11:38 AM | #20 |
how much for the ac brackets? shipped to 73160
I am a proud member of the "No, it's not for sale, I'm gonna fix it up someday" club. Last edited by kndall; 07-14-2006 at 11:39 AM. |
07-14-2006, 12:08 PM | #21 |
Does it still have the original 4x4 oil dipstick and tube? The one that curves out toward the front of the truck. If so, how much? Thanks wayne
1972 CST Blazer 350/350/205 tilt, ac, white with blue highlander plaid interior 1972 CST Jimmy 350/4speed/205 med red with black interior 1972 K20 Custom Deluxe 350/4speed/205 white/ochre/white/ochre 1972 CST Blazer 350/350/205 tach, ac, warn 5687 winch, light yellow with saddle interior 1972 CST Jimmy 350/4speed/205 dark olive with olive interior |
07-14-2006, 11:36 PM | #22 |
Truckin' Krazy
70 jimmy, no dipstick, I'm keeping the engine complete for another project. AC brackets $80 shipped,3 groove crank pullys $25 shipped, spare tire holder in great shape $20 + shipping, Transfercase crossmember $60 + shipping No heavy rust just oil & dirt on it,I have 2 other air conditioning boxs in better shape than this one $40 + shipping. The only alternator bracket I have is cracked.
07-14-2006, 11:51 PM | #23 |
Thanks but I shall pass. I am sure I can get them around here, I just have to take a stick to kill the snakes at the salvage, LOL
I am a proud member of the "No, it's not for sale, I'm gonna fix it up someday" club. Last edited by kndall; 07-14-2006 at 11:51 PM. |
07-15-2006, 07:09 AM | #24 |
Tom;
Pick out the best ( No damage, and most complete ) A/C box with evap. coil & TEV you have, and let me know what shipping will be to 03873. ( Maybe the one in the top left pic ) Do you have a good damper that goes in the cowl for the A/C ? Do you have both pulleys, crank & water pump? If so throw them in the box and let me know the total. I'm going to pass on the crossmember for now, I think shipping would be a killer on that. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 07-15-2006 at 08:16 AM. |
07-17-2006, 11:48 PM | #25 |
Not a bad nut after all..
I need a speedometer adapter box (that funny box that mounts between the transfer case and the speedometer cable).
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
