Active Member
![]() Join Date: Feb 2000
tilt column with key in column
what tilt column with a key in the column will fit a 67-72 truck, floor shift. thanks
blood type; Retumbo
Re: tilt column with key in column
pretty much any GM will fit. you just need to cut a slot in the tube for the locating tab. the problem is the plastic sleeve looks crappy and the tube area under the cluster looks like something is missing. if I can find my camera I will take pics to show you why.
Active Member
have you had a chance to take some pictures? I'm still trying to find out what column will fit best.
ttt
