Old 07-11-2006, 12:29 PM   #1
tom71
what happened to flint mi
tom71's Avatar
i need to hot wire my rig
i lost the keys to my entire life over the weekend luckily i pulled the keys to my dd off the ring , but i have lost the keys to my 71 blazer anybody on here know how to hot wire one of these trucks with out ruiming the wiring? can i jump wires in the plug that goes to the back of the ignition switch? thanks for any help .......tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 07-11-2006, 12:50 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: i need to hot wire my rig
get another ignition switch, reach under dash and remove wireing plug from old switch and plug it into your new switch. Now you can drive the blazer. then you need to work on removing the cylinder in the old switch still in the dash.
That is one thing that is scary about these trucks, just walk around with your own ignition switch, jump into any 67-72 truck, pull the wires and plug into your switch and drive off.....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 07-11-2006, 12:59 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I remember about 10 years ago where I use to live there was a TON of early 70's F150's that were stolen that way.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-11-2006, 02:55 PM   #4
RicksTrucks
RicksTrucks's Avatar
Also good to have more than one copy of each key.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 07-11-2006, 03:12 PM   #5
tom71
tom71's Avatar
jon thanks for the advice i ll be doing that
ricks yeah i know i just hadnt gotten around to it i usually keep extra keys in my wallet but , oops. and dont you need the key to get the old ignition out ??
97 fiance mobile
Old 07-11-2006, 04:25 PM   #6
truckdude239
truckdude239's Avatar
only if you want to keep it if not beat it out or something
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-11-2006, 04:43 PM   #7
matthufham
you need the key to get the old cylinder out, but it's worthless without the key. cut the bezel off the front and the ignition will pop out the back and then ... well buy a new switch, bezel, and maybe spacer if u can't get it off, but it should come off. that's what i did. plus i got a kit with matching door keys. after getting the switch assembly out of the dash, somehow the cylinder fell out.
to remove the bezel, i cut a slot with a cut off wheel past the lip of the bezel every 3/8ths of an inch and got needle nose pliars to bend that section up and it would snap off. after taking off about 3/4 of the edge it falls through the hole out the back
matthufham is offline   Reply With Quote
Old 07-11-2006, 06:06 PM   #8
MisterMan
MisterMan's Avatar
some poor man on here (i was reading) got his truck stolen.. they hot-wired the hei.... found it down the street, eveything fryed... must have sucked!!!! after ya replace that ignition... GET AN ALARM!!!
MisterMan is offline   Reply With Quote
Old 07-11-2006, 10:21 PM   #9
67chevy2wd
67chevy2wd's Avatar
If I ever get mine running I plan on putting a master shutoff switch somewhere hidden on mine.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
