07-11-2006, 03:38 PM | #1 |
Will this blazer stuff fit?
I had mentioned wanting to use this tailgate filler panel and bumper on my SWB, so will this stuff swap straight from a blazer over to a pickup? What about the mounting brackets for the bumper?
There's a junk blazer behind where I work and I think it's got all these parts, so it'd be great if they'd work.
~Steve~
Friesen High Performance Auto and Graphics Toy: 87 Shortwide, 406 smallblock with a little boost My 87 buildup Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean. |
07-11-2006, 03:47 PM | #2 |
Slots go on anything!
Re: Will this blazer stuff fit?
The middle bumper brackets are made onto the frame on a Blazer. I think you might be able to cut the frame ends off and reweld them to your frame. The outer braces will work fine. I think the tailgate band will work if you can swap out the inner bracketry.
1974 Jimmy- 5.3/4L80e/NP241 |
07-11-2006, 06:01 PM | #3 |
Oh,you can't buy that new
band does not have cutout in center for tailgate handle . crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
07-11-2006, 10:59 PM | #4 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
07-11-2006, 11:11 PM | #5 |
Happy to be here
The Blazer band can be made to work, but you need a handle relocater kit...
07-12-2006, 12:55 PM | #6 | |
N2, that is EXACTLY what I'm looking for!!!! Well, the only difference is that the pictured one doesn't have a parachute on it I just couldn't locate a picture of what I wanted. Now can someone tell me if that is all blazer stuff or if I have to order some other parts? I checked the blazer behind our shop and she's got all those parts.
~Steve~
Friesen High Performance Auto and Graphics Toy: 87 Shortwide, 406 smallblock with a little boost My 87 buildup Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean. Last edited by 1987 Shortwide; 07-12-2006 at 12:57 PM. |
07-12-2006, 09:31 PM | #7 |
www.73-87chevytrucks.com
Band is the same,
Bumper is the same OUTER brackets are the same There is no inner brackets on a Blazer. And as N2 stated, you will have to relocate the handle.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
07-12-2006, 09:41 PM | #8 | |
07-12-2006, 10:33 PM | #9 |
I'm not too concerned about the inner brackets, the bumper is there solely for looks and nothing more. I'm going to try to get all the stuff cheap enough that I can keep my shaved tailgate on hand, but I really like that stock clean look. And yes, I already intended on relocating this handle too...
~Steve~
07-13-2006, 12:46 AM | #10 |
I got the inner brackets from Chevy Duty. I'm pretty sure Jeff offers them on his site too.... http://www.73-87chevytrucks.com/merc...387RearBumpers .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-13-2006 at 12:48 AM. |
07-13-2006, 07:04 AM | #11 | |
yeller
Steve, if Chris sells them, get them from him...great service and he is "one of us".
07-13-2006, 08:27 AM | #12 | |
I'll be sure to look into that. I'm all anxious to see this setup on there now I think I'll have to go steal my dad's parachute for mach-up purposes even though I really don't need one yet... (need it at 150mph trap speeds, I'll be happy/lucky with 130mph on this setup) but it is a nice feeling when you're pushing a 4000 lb. brick on stock brakes down the 1320.
~Steve~
07-13-2006, 01:11 PM | #13 | |
Insert Witty Text Here
Can a trailer hitch be used with that bumper? I would assume a receiver type for a pickup would still fit, but mine bolts to the frame and bumper. Slonaker |
07-13-2006, 03:35 PM | #14 |
Here's another question...
What about that filler panel that goes right in front of the bumper to fill the gap between the body and itself? What I'm wondering (need to go look at that one behind the shop again), is whether you could shorten that bumper a few inches and suck it up close enough to the body that you wouldn't need that filler panel. The licence plate opening is pretty wide anyhow, so narrowing that up would help the appearance of the bumper alot IMO.
~Steve~
07-13-2006, 04:19 PM | #15 |
some good info here about the brackets: http://67-72chevytrucks.com/vboard/s...86#post1756086
1987 350 TBI lowered 5/7 |
07-13-2006, 05:50 PM | #16 |
yeller
Steve, all you have to do to tuck the bumper is oblongate the holes on the brackets where they mount to the frame...and maybe cut the ends of the brackets a little shorter in order to tuck them in. Once you have the brackets modified, you should be able to slide them in and out however much you want since the holes are now oval and not round. Make sense? I plan on doing this on Yeller when I get that far.
I wanted to do the same on the front, but the inner bolts mount directly to the frame...which sits tight against the back of the bumper...so I would need to whack off some of the frame. Not something I want to do...so the front will stay where it is.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 07-13-2006 at 05:52 PM. |
07-14-2006, 07:17 AM | #17 | |
I've never minded the front bumper where it's at, so it'll stay. In looking at this blazer behind our shop I noticed that the opening for the tag is pretty wide, so the bumper wouldn't hurt to lose about 2-3" out of the center, and that would really set the sides up to the rear quarters nice. This bumper is in good shape but it could use a re-chrome, so I don't feel too bad if I decide to hack it up a little. I will say however that if I go so far as to narrow it, there won't be bolt heads on it anymore either.
~Steve~
