Old 07-11-2006, 11:19 PM   #1
76bonanza
76bonanza's Avatar
rubber hose question
What is the best way to shine rubber rad hose? Can you use a tire shine product? Also I assum you can use simply green on them with out damage?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-12-2006, 03:06 AM   #2
dion
72 Cheyenne
dion's Avatar
Re: rubber hose question
I use armor all on mine sometimes, seems to clean them up a bit.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-12-2006, 03:50 AM   #3
blaserman
blaserman's Avatar
I have used Armor All and tire shine both with good results. I clean them up first with soapy water dry them and then used both. It is up to you what you want to use. Try both and see.
This is my best friend
blaserman is offline   Reply With Quote
Old 07-12-2006, 08:38 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I haven't used it on hoses, but 303 works very nicely on tires, as well as vinyl and plastics.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-12-2006, 11:15 PM   #5
71chevytruckguy
71chevytruckguy's Avatar
i use armor all on mine when gettin it ready for shows. doesn't last very long though. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
